Hi experts,
I am using DVD slideshow GUI, which is a great program, to generate a picture slide show with a great menu navigation generator. It only allows import of mp3 or wav files though... I have a 5.1 AC3 file that I want to use...
Here are the files that DVD slideshow GUI generates if I use the export all option:
December 2006.ac3 -> (This is a blank file as I didn't specify any audio)
December 2006.dsg
December 2006.m2v
December 2006.txt
Here are the files that DVD slideshow GUI generates if I select export to GFD:
December 2006_180.ac3 -> (This is a blank file as I didn't specify any audio)
December 2006_e0.m2v
December 2006.gfd
So I can import the dsg file into GUI for DVDAuthor and all of the menu stuff is perfect. How can I go about adding the 5.1 AC3 file and/or delete the empty ac3 file?
Thanks,
Chris
Results 1 to 12 of 12
...I have a 5.1 AC3 file that I want to use...
For the menu or for the slideshow (which is a 'Film' in GfD)?GUI for dvdauthor:
http://www.videohelp.com/~gfd/
For the slideshow.
Thanks,
Chris
Have you tried contacting the author? I find it bizarre that this programs allows you to use MP3 because that is completely invalid for DVD. It must be converting those to WAV. If you don't get an answer from anyone, you will probably have to convert your 5.1 AC3 file to 2 channel WAV and import that. You can do this kind of conversion through BeSweet GUI and other programs.
You have demaxed your compilation and have .m2v file.
Put your .m2v in MuxMan and import your AC3 audio also - remux. You will end up with what you want.
Just make sure that length of both files is same.
Tinker,
Not sure I follow you. My AC3 files are not even close to the same size as 5.1 format uses a lot more space than stereo.
Muxman will mux the video and audio but then how do I add the menu stuff to it?
Thanks,
Chris
Hi-
My guide is for editing menu backgrounds, but the same principles apply for substituting in a new audio:
http://forum.videohelp.com/topic313743.html#1606732
If your 5.1 ac3 file has the same length as the rendered m2v slideshow file, can't you just change it in GFD? (Right click on the film and change the audiofile? Look here: http://download.videohelp.com/gfd/He...ileDialog.html
(I have no idear how a .ac3 5.1 audiofile is treated in GFD, newer tried it.)
DSG converts from mp3 and wav(most used formats for music) to ac3 or mp2(used by dvdauthor and muxman)I find it bizarre that this programs allows you to use MP3 because that is completely invalid for DVD.
I did not say "same SIZE" I said "Same LENGTH" in hours, min. And this means length of your .m2v and AC3 5.1 file.
Once you have maxed your show, you can replace it back in the DVD Authoring program and use your old menu or make new one.
GUI for dvdauthor:
Excellent. I will try this when I get home.
They are the same length as I just upmix it.
Thanks for everyones input!
Chris
Ok, I replaced the existing AC3 with the new 5.1 AC3 in GFD and it works when I play the slideshow.
Thanks,
Chris
How to add subtitles permanently to existing mp4 h.264 file???
By Patrick_H in forum SubtitleReplies: 7Last Post: 8th May 2011, 21:23 -
add tones to existing mp3 file
By lordhutt in forum ComputerReplies: 0Last Post: 28th Dec 2010, 13:25 -
Extract from avi file and add to existing mkv file
By pathumx in forum MacReplies: 6Last Post: 8th Apr 2010, 18:57 -
Add menu to existing DVD?
By MilesAhead in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 2nd May 2008, 17:56 -
Add Dolby Digital to an existing VOB file
By ianwuk in forum AudioReplies: 4Last Post: 13th Jul 2007, 10:09
