VideoHelp.com Forum
Results 1 to 10 of 10
  1. Hi
    How do I gat a Panasonic VDR-D100 DVD Camcorder to work on a mac.
    Thank You!!!
    P.S. God Love You And Have A Good Day!!!
    goto http://god1.no-ip.org
  2. Member terryj's Avatar
    Your Camcorder
    Since it uses USB, it might be compatible with the new
    iMovie 08, bundled with iLife 08. ($80)
    But don't quote me on that, or take it as gospel.
    Macs prefer FW based camcorders as a default,
    so you may be SOL as far as direct connectivity.
    The discs it records to should be able to be finalized
    in camera though, and then these could be
    have their data extracted using MPEGStreamclip
    (with QT Mpeg-2 addon, $20).
    But I don't believe at this time there is a simple
    1-2 method of using this camcorder with a Mac.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  3. It did not work for me.
    Thank You!!!
    "It"? The direct import from the camcorder or the conversion via MPEG Streamclip?
  5. The direct import from the camcorder.
    The mini dvd will not go into my macbook.
    Thank You!!!
  6. Member dcsos's Avatar
    Physical Media Constaint reached
    (slot drives are unable to play MINI DVD even with a CADDY)
    external tray drive only way to go
  7. Yes I know that slot drives not play MINI DVD.
    Thank You!!!
  8. Hi
    I got it to work.
    Thank You!!!
  9. Member dcsos's Avatar
    HOW?
    otherwise, I wouldn't bother helping you again if I can't learn from my mistakes
    I'm not sure I have the answer. Take a look at my personal file on the VDR-D100. It has all my documentation on the Panasonic camcorder.
    http://personafile.com/Panasonic-Dig...7988981344.htm
  1. Replies: 3
    Last Post: 15th Aug 2010, 05:45
  2. vro on file on my panasonic vdr-d150gn
    By vpholdie in forum Newbie / General discussions
    Last Post: 14th Aug 2009, 19:05
  3. Panasonic D100 MPEG 2 Files
    By Invicta in forum Video Conversion
    Last Post: 15th Nov 2008, 02:07
  4. Replies: 3
    Last Post: 15th Oct 2008, 14:34
  5. Is a Panasonic VDR-D100 DVD Camcorder?
    By crocker5731 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 12th Sep 2007, 19:40
