I would like to hook up my computer to my monitor and tv. I have a ati x850 graphics with a digital and analog output. I would be using a hdmi to dvi cable to hook up my tv and a regual analog input for my dell monitor. Is it possible to use both the tv and monitor or do I have to use one or the other?? if this is possible is it possible to use the two as different desktops where I can drag my cursor from one monitor to the other???
Thread: dual monitors
So far as I know the x850 is a dual monitor card. The x850 is a "Theater 200" card not AVIVO so don't expect much HDTV performance. I'd connect the VGA to the HDTV if it has it and the DVI to the computer monitor for best performace. Set the VGA to the native resolution of your HDTV. Get the latest drivers. Follow the manual and the Catalayst help for dual monitor set up.
http://ati.amd.com/products/radeonx850/index.htmlRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
ATI Catalyst dual monitors
By dfisher052 in forum ComputerReplies: 29Last Post: 12th Apr 2011, 16:05 -
Windows 7 w/ dual monitors
By triptych in forum Newbie / General discussionsReplies: 3Last Post: 1st Nov 2009, 02:03 -
Dual Monitors help
By Cragsterboy in forum Newbie / General discussionsReplies: 4Last Post: 3rd Oct 2009, 10:20 -
Video Disappears On Dual Monitors
By DJboutit in forum Newbie / General discussionsReplies: 4Last Post: 5th Sep 2009, 16:57 -
Is it possible to run 2 instances of 1 game on 1 PC with dual monitors?
By Rudyard in forum ComputerReplies: 12Last Post: 19th Jun 2007, 22:26
Statistics
Newest guides
Latest tool updates
New media comments
