I am using a dvd cam to shoot short movies. Upon finishing the disc I finalized it on the camcorder.It should have 20 scenes on the disc but turn out only 1 scene(the first) can be seen. So I wondered where are the rest gone.
May be they are gone for good,I thought. I put the disc on to my computer and open Windows Explorer and lord and behold there is this VIDEO TS folder and in it there are VTS01 1 ,VTS01 2 VOB files. I clicked on these and see all the videos are playing. Great.
So I used CopyToDvd tried to burn a dvd out of it. It turn out again only the first scene is seen.The rest is not .I believe it has something to do with IFO file but how do I correct it? Anyone?
Results 1 to 9 of 9
Use a more descriptive title to your posts, please. I've changed this for you.
/Mats
Thanks for the change.Anybody has ideas to resolve the problem I posted?
Ok, VOB2MPG will convert the vob file to mpg file. But the aspect retio has changed to 4:3. Is there a fix on this?I tried use VD to do the job but it does not even open the mpg.
VirtualDubMod (and VirtualDubMpg2) will open mpg, but that's not what you want.
If you're certain the AR has changed from 16:9 to 4:3, patch it back to 16:9 with DVDPatcher. Then it's just a matter of authoring the mpg as Video DVD.
/Mats
VOB2MPG does screw up the AR flag when it rips form some discs. Don't know why, but I know all the extracts from my Pioneer DVDR 16:9 discs produce 4:3 mpg files. A suggested above, patch them back then author as 16:9
When I use Windows Media Player to play the mpg the AR did change to 4:3 and stayed that way.I can not drag to change the ratio. However,when I used Power DVD I was able to change the ratio to it's original form.So I'll settle for that.
Little is said with regard to VOB2MPG. There's no manual or instruction for it. I've found that it use much memory space than expected.I don't know if anyone experienced running out of memory while program is excecuting.
I use it with 1GB of RAM and have never even come close to having it run out.
That's strange.I have 1.5 GB physical. The program ran normally untill 85% then it slows right down to a snail pace. I've tried three times with identical results. The DVD-RW has only 1.4 GB capacity and is a small disc.
Anyways,thanks for everyone's response to my question.Have a good day!
mpg-videos 'burnable' on 'viewable' DVD-R without converting process?
By video-fan in forum Authoring (DVD)Replies: 8Last Post: 12th Oct 2011, 07:03 -
How to increase when TC OR CAM DVD to Tc or Cam rip
By antonymaheshca in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2010, 13:42 -
Extracting Time Data from Mpeg2 Stream (Hard Disk Cam)
By gallion311 in forum Video ConversionReplies: 2Last Post: 1st Dec 2008, 09:55 -
Ripping A DVD onto the HDD in a Viewable Format
By kiln in forum Newbie / General discussionsReplies: 2Last Post: 18th Apr 2008, 16:42 -
multiple .avi files on a DVD-R that is viewable on a standard DVD player
By ottawadave in forum Video ConversionReplies: 8Last Post: 18th Jul 2007, 11:32
