  1. There's a video I want that I can only find streamed from one place. They use the Divx Web Player and I was hoping someone could point me at a tool that would allow me to keep the video?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    There are tools for capturing streaming video. Check in the Tools section.
    Google is your Friend
  3. I haven't yet found one that will do divx streaming.
  4. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    If you put the url in WMP (and most other players) when the video has fully pre-loaded into the temp folder the "save as" option should no longer be grayed out.
    If that doesn't work, for a direct download, you could try Url Snooper it will reveal the true location of the file I didn't put a link to it but its easy to find with Google search.
  5. Member nTekka's Avatar
    Jun 2007
    Iono where you watched the DivX video, but usually DivX Player has a "Right-click" menu and it has a save option...All of Stage6 DivX movies are savable with the right click.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    The right-click option should work, but only after the movie has completely downloaded. Stage6 also has a download option to save you streaming the content, but most sites that paggy-back off it offer only streaming.
    You can also configure your Divx player software to automatically copy downloaded content to an off-line folder for later play back.
    Read my blog here.
