how topen flac file?How do I convert it to mp3 or toher audio formats?
Results 1 to 12 of 12
Thread: what is flac file?
I can't live without my computer.
MediaCoder should be able to convert them. Or more info about flac: http://flac.sourceforge.net/
Flac is a lossless compresion for audio.
http://forum.videohelp.com/topic334109.html#1734181
Use this to extract the WAV file,
Trader's Little Helper
then destroy it by MP3'n it
Originally a member since 2001, LONG LIVE TARAN's!!!
Noahtuck, That link for TLH doesn't work anymore and ALL links seem to point to it alone. Do you have a copy? (If that's OK...)
You can always try BonkEnc (http://www.bonkenc.org/ ). I can't remember if CDex will do it with a Winamp FLAC plugin installed. Winamp certainly will.
Of course, I think they do have basic encoders/decoders (and probably links to more converters) at the FLAC homepage.
The dbPowerAmp converter should also do it, with FLAC support installed, though I'm not sure about the recent versions, since they've changed a lot.
aruwin: If you're primarily just interested in listening to the music in FLAC format, most of the recent software players (such as Winamp, foobar, xmplay, etc.) should be able to play them - though you may need to have a plugin installed for your specific player.If cameras add ten pounds, why would people want to eat them?
Foobar2000 can do it. So can Audacity, both are free.
There is no such thing as "Idiot-Proof".........a good Idiot will get around that every time.
Hi
I have just used Audacity, Flac to WAV then WAV to Mp3
http://forum.videohelp.com/topic336454.html
I just tried the link in my post and it takes me right to their main homepageOriginally Posted by Cornucopia
http://thor.prohosting.com/roh0205/
And the link to the direct DL is near the bottom of the page.
Let me see if i can upload the install exe here....
been ahwile since i uploaded a zip or file other than a photo here so it may take a second to get it right
Edit:
Okay, that did not work, said page not found here on Vhelp.
Let me try it in a zip.
tralih11190.zip
To heck with it, here's a link to it on a filesharing site
http://www.savefile.com/files/1039802
Nice little program, i used to use Flac frontend but pretty much use this exclusively now, as it handles pretty much all lossless forms if audio compression/archiving.
Traders of lossless compressed audio files (e.g. ape, flac, mkw, or shn files) have to handle a lot of different applications to decode, encode, create/verify checksums, fix sector boundary errors, or create torrent files. Moreover some are command line programs requiring a deeper knowledge of how to use various parameters. Trader's Little Helper bundles all the important features of those applications in one single easy-to-use frontend.Originally a member since 2001, LONG LIVE TARAN's!!!
Or have a look at dBPowerAmp that uses plug-ins for each format it supports so they can and do get updated without having to update the main software
It now also supports multi-core processors, very high quality conversion and a lot, lot more. Like support nearly 99% of all portable MP3 players including Apple's
You can convert to or from any format it supports, including the more common lossless formats I come acroos like APE, SHN and FLAC, and will easily convert them back to WAV or MP3 very quickly
Yes, there's a FLAC plugin for winamp. Google for FLAC WinAmp.
/Mats
Plain ol' Windows Media Player can do flac files if you install the OGG codecs. Google that for more info.
Bob Simandl ... somewhere near St. Louis
Your mortgage is not my problem.
FLAC into AVI file
By JOHNINA in forum Video ConversionReplies: 2Last Post: 5th Sep 2010, 20:01 -
Converting .flac to .aiff - retaining file name
By macbuz in forum AudioReplies: 1Last Post: 21st Nov 2009, 20:02 -
how to split a FLAC file?
By tomchook in forum AudioReplies: 4Last Post: 9th Mar 2008, 22:04 -
FLAC file format question
By Neil_2004 in forum Video ConversionReplies: 3Last Post: 25th Dec 2007, 10:47 -
FLAC, should i use this?
By SE14man in forum Newbie / General discussionsReplies: 23Last Post: 7th Aug 2007, 09:17
