When I convert DVD rips to dvd format, I save them to my hard drive first and burn them later. When converting the file to my hard drive I get about 10 mins into the process and my computer completely shuts down...What could be the problem??I tried to uninstall Nero 7 and install it again and still the same problem, my computer shuts down when in the coversion process from dvd rip to DVD format
Thread: Nero Problem
Try using something else - ConvertXtoDVD, FAVC or DVD Flick are all better than Nero.
If it still shuts down after about the same time then you may have a cooling problem. To test if you do, take the side of the case off the PC, aim a small desk fan into the case, and try encoding again. If it doesn't shut down this time then you know you need to get a new cooling fan for your PC.
I have a laptop so how would I go about getting cool air into it??Thanks
If it is a laptop that is overheating then you would have to have it serviced and have the fans replaced.
Start by changing software to see if that helps.
Nero problem
By Doopopmercury in forum Newbie / General discussionsReplies: 8Last Post: 11th Apr 2012, 06:14 -
Problem with nero. I think!
By breeze9 in forum Video ConversionReplies: 3Last Post: 9th Jun 2008, 11:40 -
Nero burnig problem.
By BradBo1140 in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Oct 2007, 05:14 -
nero burning problem
By peterjitonks in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2007, 13:40 -
problem with Nero
By moe_b_disc in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2007, 05:13
Statistics
Newest guides
Latest tool updates
New media comments
