    Which do you like better?
    I personally am on CS3 and i love it. Although i do envy Final Cut 6 for having the Smooth Cam feature (very cool)
    premiere pro cs3 is much better than fcp
    They're really geared for different uses.
  4. Member edDV's Avatar
    So you're saying you can't hold the cam steady?
    http://www.kiva.org/about
    funny guy. Well i can. The problem is when im editing footage that other people shot, like home videos. Im pretty sure you can guess how steady those are. This feature would really be helpfull.
  6. Member edDV's Avatar
    There's nothing that locks Pixlock iStabilize to Final Cut Pro. It's a standalone program that's been around.
    http://www.pixlock.com/index.php?Itemid=33&id=13&option=com_content&task=view
    Part of a class of software that is getting there but no substitution for proper camera technique or hardware image stabilization.
    http://en.wikipedia.org/wiki/Image_stabilization
    An entry version of 2d3 SteadyMove Pro comes free with Premier Pro CS3.
    http://www.2d3.com/html/products/steadymove_overview.html
    Then there's the Open Source Deshaker.
    http://www.sundancemediagroup.com/articles/deshaker_guide.htm
    Also SteadyHand
    http://www.goodervideo.com/work/index.html
    And one built into After Effects
    Don't expect automation, once the exposure is blurred, recontruction is an approximation.
    Thanks for all the links. Problem is that i still dont see one that works with CS3. 2d3 specifically says at the bottom of the page you linked that it doens't work with CS3
    I have done it with After Effects CS3, but its kind of a pain. It just seems more integrated in Final Cut. Simpler. In after effects i have to set the points and then reimport it to Premiere. Slow as hell. Of course only have a 2.8GHZ P4
