VideoHelp.com Forum
Results 1 to 25 of 25
Thread: VOB2MPG error
    I Think this is the right forum...
    In VOB2MPG I get the error that "ffmpeg.exe has stopped working" in windows vista ultimate 64 when i clkick the start button. when i click ok it says 1 vob set prossesed but the mpeg it generates is corrupt? any suggestions
  2. Member ChrissyBoy's Avatar
    Can you post the log for this run?
    I'm sorry I have looked and don't know how to find that file
  4. Member ChrissyBoy's Avatar
    Logs are kept in the "logs" folder under where you installed the program.
    I do not have a logs folder... just
    ffmpeg
    pthreadGC2.DLL
    VOB2MPG.exe
  6. Member ChrissyBoy's Avatar
    ok.... Perhaps you can reinstall in a folder other than "Program Files" and when you run the program do "Run as Administrator..." on the VOB2MPG.exe file.... hopefully this way we will get a log.
    ahhh ok installed it on desktop and I got the following log when I got the error.
    11:32:58: 01/01/2003 05:24 PM 1,024,202,752 VTS_01_2.VOB
    11:32:58: 01/01/2003 05:24 PM 107,632,640 VTS_01_3.VOB
    11:32:58: 9 File(s) 2,185,031,680 bytes
    11:32:58: 2 Dir(s) 119,088,476,160 bytes free
    11:32:58: Not enough storage is available to process this command.
    11:32:58: C:\Users\dswofford\Desktop\Primitive\VIDEO_TS>
    ********************** AV Details *******************
    file=C:\Users\dswofford\Desktop\Primitive\VIDEO_TS \VTS_01_1.VOB
    FormatName=mpeg
    Num_Frames=61349
    DurationInSecs=2047
    Duration=00:34:07.0
    VideoCodec=mpeg2video
    VideoFFSTNum=0
    Width=720
    Height=480
    Standard=NTSC
    BitRate=4002
    AudioStreamCount=1
    Audio1FFSTNum=1
    Audio1StreamID=[0x1c0]
    Audio1SampleRate=0
    Audio1Codec=mp2
    Audio1BitRate=0
    Audio1Channels=0
    ************************ END ************************
    ********************** Output Folder *******************
    11:33:07: Volume in drive C has no label.
    11:33:07: Directory of C:\Users\dswofford\Desktop\Primitive\VIDEO_TS
    11:33:07: 09/06/2007 08:09 AM <DIR> .
    11:33:07: 09/06/2007 08:09 AM <DIR> ..
    11:33:07: 01/01/2003 05:24 PM 32,768 VIDEO_TS.BUP
    11:33:07: 01/01/2003 05:24 PM 32,768 VIDEO_TS.IFO
    11:33:07: 01/01/2003 05:21 PM 28,772,352 VIDEO_TS.VOB
    11:33:07: 09/06/2007 11:32 AM 0 VTS_01.mpg
    11:33:07: 01/01/2003 05:24 PM 55,296 VTS_01_0.BUP
    11:33:07: 01/01/2003 05:24 PM 55,296 VTS_01_0.IFO
    11:33:07: 01/01/2003 05:24 PM 1,024,247,808 VTS_01_1.VOB
    11:33:07: 01/01/2003 05:24 PM 1,024,202,752 VTS_01_2.VOB
    11:33:07: 01/01/2003 05:24 PM 107,632,640 VTS_01_3.VOB
    11:33:07: 9 File(s) 2,185,031,680 bytes
    11:33:07: 2 Dir(s) 119,088,291,840 bytes free
    11:33:07: Not enough storage is available to process this command.
    11:33:07: C:\Users\dswofford\Desktop\Primitive\VIDEO_TS>
    Bump
  9. Member ChrissyBoy's Avatar
    Can you download and install SVCD2DVD and replace the the ffmpeg.exe file in the VOB2MPG folder with the one from SVCD2DVD? Lets first see if that resolves the issue before we try other things.
    Nope still doesn't work after that and I get
    ************************ SYSTEM INFORMATION ************************
    ***************************** VOB2MPG *****************************
    Title:
    Version: 2.5.0.0
    Executable: C:\Users\dswofford\Desktop\V2M\VOB2MPG.exe
    Executable size: 460 KB
    Executable size in bytes: 471040
    Executable CreationTime: 1/1/2000 12:00:00 AM
    Executable LastWriteTime: 1/1/2000 12:00:00 AM
    Executable LastAccessTime: 1/1/2000 12:00:00 AM
    ****************************** Drives *******************************
    DeviceID: C:
    FileSystem: NTFS
    FreeSpace: 116 GB
    ********************* END OF SYSTEM INFORMATION ********************
    ********************** Input Folder *******************
    22:16:05: Volume in drive C has no label.
    22:16:05: Directory of C:\Users\dswofford\Desktop\Primitive\VIDEO_TS
    22:16:05: 09/06/2007 08:09 AM <DIR> .
    22:16:05: 09/06/2007 08:09 AM <DIR> ..
    22:16:05: 01/01/2003 05:24 PM 32,768 VIDEO_TS.BUP
    22:16:05: 01/01/2003 05:24 PM 32,768 VIDEO_TS.IFO
    22:16:05: 01/01/2003 05:21 PM 28,772,352 VIDEO_TS.VOB
    22:16:05: 09/06/2007 11:32 AM 0 VTS_01.mpg
    22:16:05: 01/01/2003 05:24 PM 55,296 VTS_01_0.BUP
    22:16:05: 01/01/2003 05:24 PM 55,296 VTS_01_0.IFO
    22:16:05: 01/01/2003 05:24 PM 1,024,247,808 VTS_01_1.VOB
    22:16:05: 01/01/2003 05:24 PM 1,024,202,752 VTS_01_2.VOB
    22:16:05: 01/01/2003 05:24 PM 107,632,640 VTS_01_3.VOB
    22:16:05: 9 File(s) 2,185,031,680 bytes
    22:16:05: 2 Dir(s) 125,041,991,680 bytes free
    22:16:05: Not enough storage is available to process this command.
    22:16:05: C:\Users\dswofford\Desktop\Primitive\VIDEO_TS>
    Title:
    Version: 2.5.0.0
    DeviceID: C:
    FileSystem: NTFS
    FreeSpace: 116 GB
    22:16:09: Volume in drive C has no label.
    22:16:09: Directory of C:\Users\dswofford\Desktop\Primitive\VIDEO_TS
    22:16:09: 09/06/2007 08:09 AM <DIR> .
    22:16:09: 09/06/2007 08:09 AM <DIR> ..
    22:16:09: 01/01/2003 05:24 PM 32,768 VIDEO_TS.BUP
    22:16:09: 01/01/2003 05:24 PM 32,768 VIDEO_TS.IFO
    22:16:09: 01/01/2003 05:21 PM 28,772,352 VIDEO_TS.VOB
    22:16:09: 09/06/2007 11:32 AM 0 VTS_01.mpg
    22:16:09: 01/01/2003 05:24 PM 55,296 VTS_01_0.BUP
    22:16:09: 01/01/2003 05:24 PM 55,296 VTS_01_0.IFO
    22:16:09: 01/01/2003 05:24 PM 1,024,247,808 VTS_01_1.VOB
    22:16:09: 01/01/2003 05:24 PM 1,024,202,752 VTS_01_2.VOB
    22:16:09: 01/01/2003 05:24 PM 107,632,640 VTS_01_3.VOB
    22:16:09: 9 File(s) 2,185,031,680 bytes
    22:16:09: 2 Dir(s) 125,041,991,680 bytes free
    22:16:09: Not enough storage is available to process this command.
    22:16:09: C:\Users\dswofford\Desktop\Primitive\VIDEO_TS>
    FormatName=mpeg
    Num_Frames=61349
    DurationInSecs=2047
    Duration=00:34:07.0
    VideoFFSTNum=0
    Width=720
    Height=480
    Standard=NTSC
    BitRate=4002
    AudioStreamCount=1
    Audio1FFSTNum=1
    Audio1SampleRate=0
    Audio1Codec=mp2
    Audio1BitRate=0
    Audio1Channels=0
    22:16:12: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
    22:16:12: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
    22:16:12: libavutil version: 49.1.0
    22:16:12: libavcodec version: 51.27.0
    22:16:12: libavformat version: 51.12.1
    22:16:12: built on Jul 10 2007 10:39:43, gcc: 4.3.0 20061204 (experimental)
    22:16:12: Input #0, mpeg, from 'multi:C:\Users\dswofford\Desktop\Primitive\VIDEO_ TS\VTS_01_1.VOB*C:\Users\dswofford\Desktop\Primiti ve\VIDEO_TS\VTS_01_2.VOB*C:\Users\dswofford\Deskto p\Primitive\VIDEO_TS\VTS_01_3.VOB*':
    22:16:12: Duration: 01:09:56.6, start: 0.228167, bitrate: 4110 kb/s
    22:16:12: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x480, 8000 kb/s, 29.97 fps(r)
    22:16:12: Stream #0.1[0x1c0]: Audio: mp2
    22:16:12: Assuming NTSC for target.
    22:16:12: Output #0, dvd, to 'C:\Users\dswofford\Desktop\Primitive\VIDEO_TS\VTS _01.mpg':
    22:16:12: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=2-31, 8000 kb/s, 29.97 fps(c)
    22:16:12: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
    22:16:12: Stream mapping:
    22:16:12: Stream #0.0 -> #0.0
    22:16:12: Stream #0.1 -> #0.1
    22:16:12: Press [q] to stop encoding
    22:16:13: Volume in drive C has no label.
    22:16:13: Directory of C:\Users\dswofford\Desktop\Primitive\VIDEO_TS
    22:16:13: 09/06/2007 08:09 AM <DIR> .
    22:16:13: 09/06/2007 08:09 AM <DIR> ..
    22:16:13: 01/01/2003 05:24 PM 32,768 VIDEO_TS.BUP
    22:16:13: 01/01/2003 05:24 PM 32,768 VIDEO_TS.IFO
    22:16:13: 01/01/2003 05:21 PM 28,772,352 VIDEO_TS.VOB
    22:16:13: 09/11/2007 10:16 PM 0 VTS_01.mpg
    22:16:13: 01/01/2003 05:24 PM 55,296 VTS_01_0.BUP
    22:16:13: 01/01/2003 05:24 PM 55,296 VTS_01_0.IFO
    22:16:13: 01/01/2003 05:24 PM 1,024,247,808 VTS_01_1.VOB
    22:16:13: 01/01/2003 05:24 PM 1,024,202,752 VTS_01_2.VOB
    22:16:13: 01/01/2003 05:24 PM 107,632,640 VTS_01_3.VOB
    22:16:13: 9 File(s) 2,185,031,680 bytes
    22:16:13: 2 Dir(s) 125,041,856,512 bytes free
    22:16:13: Not enough storage is available to process this command.
    22:16:13: C:\Users\dswofford\Desktop\Primitive\VIDEO_TS>
  11. Member ChrissyBoy's Avatar
    Ok. Can you MOVE the VIDEO_TS folder to the root of your C drive and retry?
    ok now I get ffmpeg stopped working again and now I get the follow
    Title:
    Version: 2.5.0.0
    DeviceID: C:
    FileSystem: NTFS
    FreeSpace: 109 GB
    07:56:56: Volume in drive C has no label.
    07:56:56: Directory of C:\VIDEO_TS
    07:56:56: 09/06/2007 08:09 AM <DIR> .
    07:56:56: 09/06/2007 08:09 AM <DIR> ..
    07:56:56: 01/01/2003 05:24 PM 32,768 VIDEO_TS.BUP
    07:56:56: 01/01/2003 05:24 PM 32,768 VIDEO_TS.IFO
    07:56:56: 01/01/2003 05:21 PM 28,772,352 VIDEO_TS.VOB
    07:56:56: 09/12/2007 07:55 AM 0 VTS_01.mpg
    07:56:56: 01/01/2003 05:24 PM 55,296 VTS_01_0.BUP
    07:56:56: 01/01/2003 05:24 PM 55,296 VTS_01_0.IFO
    07:56:56: 01/01/2003 05:24 PM 1,024,247,808 VTS_01_1.VOB
    07:56:56: 01/01/2003 05:24 PM 1,024,202,752 VTS_01_2.VOB
    07:56:56: 01/01/2003 05:24 PM 107,632,640 VTS_01_3.VOB
    07:56:56: 9 File(s) 2,185,031,680 bytes
    07:56:56: 2 Dir(s) 117,598,580,736 bytes free
    07:56:56: Not enough storage is available to process this command.
    07:56:56: C:\VIDEO_TS>
    file=C:\VIDEO_TS\VTS_01_1.VOB
    FormatName=mpeg
    Num_Frames=61349
    DurationInSecs=2047
    Duration=00:34:07.0
    VideoFFSTNum=0
    Width=720
    Height=480
    Standard=NTSC
    BitRate=4002
    AudioStreamCount=1
    Audio1FFSTNum=1
    Audio1SampleRate=0
    Audio1Codec=mp2
    Audio1BitRate=0
    Audio1Channels=0
    07:56:59: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
    07:56:59: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
    07:56:59: libavutil version: 49.1.0
    07:56:59: libavcodec version: 51.27.0
    07:56:59: libavformat version: 51.12.1
    07:56:59: built on Jul 10 2007 10:39:43, gcc: 4.3.0 20061204 (experimental)
    07:56:59: Input #0, mpeg, from 'multi:C:\VIDEO_TS\VTS_01_1.VOB*C:\VIDEO_TS\VTS_01 _2.VOB*C:\VIDEO_TS\VTS_01_3.VOB*':
    07:56:59: Duration: 01:09:56.6, start: 0.228167, bitrate: 4110 kb/s
    07:56:59: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x480, 8000 kb/s, 29.97 fps(r)
    07:56:59: Stream #0.1[0x1c0]: Audio: mp2
    07:56:59: Assuming NTSC for target.
    07:56:59: Output #0, dvd, to 'C:\VIDEO_TS\VTS_01.mpg':
    07:56:59: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=2-31, 8000 kb/s, 29.97 fps(c)
    07:56:59: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
    07:56:59: Stream mapping:
    07:56:59: Stream #0.0 -> #0.0
    07:56:59: Stream #0.1 -> #0.1
    07:56:59: Press [q] to stop encoding
    07:56:59: Volume in drive C has no label.
    07:56:59: Directory of C:\VIDEO_TS
    07:56:59: 09/06/2007 08:09 AM <DIR> .
    07:56:59: 09/06/2007 08:09 AM <DIR> ..
    07:56:59: 01/01/2003 05:24 PM 32,768 VIDEO_TS.BUP
    07:56:59: 01/01/2003 05:24 PM 32,768 VIDEO_TS.IFO
    07:56:59: 01/01/2003 05:21 PM 28,772,352 VIDEO_TS.VOB
    07:56:59: 09/12/2007 07:56 AM 0 VTS_01.mpg
    07:56:59: 01/01/2003 05:24 PM 55,296 VTS_01_0.BUP
    07:56:59: 01/01/2003 05:24 PM 55,296 VTS_01_0.IFO
    07:56:59: 01/01/2003 05:24 PM 1,024,247,808 VTS_01_1.VOB
    07:56:59: 01/01/2003 05:24 PM 1,024,202,752 VTS_01_2.VOB
    07:56:59: 01/01/2003 05:24 PM 107,632,640 VTS_01_3.VOB
    07:56:59: 9 File(s) 2,185,031,680 bytes
    07:56:59: 2 Dir(s) 117,598,445,568 bytes free
    07:56:59: Not enough storage is available to process this command.
    07:56:59: C:\VIDEO_TS>
  13. Member ChrissyBoy's Avatar
    What happens if you execute the following at a command prompt:
    C:\Users\dswofford\Desktop\V2M\ffmpeg -i "C:\VIDEO_TS\VTS_01_1.VOB" -y -target dvd -vcodec copy "C:\VIDEO_TS\VTS_01.mpg"
    Do you actually get the error or is the mpeg produced?
    yes I still get the error
  15. Member ChrissyBoy's Avatar
    ok can you delete the VTS_01.mpg file and retry the command line please?
    still get error and no log is created.
  17. Member ChrissyBoy's Avatar
    ok. i am not in front of vista at the moment but... Can you right click on the ffmpeg.exe file and change the compatablity to XP? Then try the command line again.... If you can force the exe to also run as administrator - can you do that also?
  18. Member
    still get the error
  19. Member ChrissyBoy's Avatar
    ok maybe an issue with the file. Can you use the attached to produce a 5 or 10 MB sample of VTS_01_1.VOB and then email it to me?
    makesample.zip
    email sent.
  21. Member ChrissyBoy's Avatar
    Nothing recieved yet... Also if you try the command line on the sample file - do you still get the error?
  22. Member
    I was having this issue when trying to use VOB2MPG for Daft Punk's DVD "Interstella 5555". In my case, VOB2MPG was installed to Program Files (x86) folder (as my computer is also Windows Vista 64-bit). My [partial] solution was to open Command Prompt in Administrator mode (right-click, Run as Administrator, allow to run as administrator) and then type that ffmpeg command above:
    "C:\Program Files (x86)\BadgerIT\VOB2MPG\ffmpeg" -i "D:\VIDEO_TS\VTS_01_1.VOB" -y -target dvd -vcodec copy "D:\VIDEO_TS\VTS_01.mpg"
    OK, ffmpeg no longer crashes, but now I am facing a new issue: ffmpeg only converts the first VOB to MPEG (does not take all VOBs and merge them into a single MPG). How do I solve this?[/code]
  23. Member ChrissyBoy's Avatar
    I think the error that dswofford1 had was due to the audio stream in the vobs.... In your case, can you reinstall in a folder off the C drive. C:\VOB2MPG for example?
  24. Member
    Re-installing VOB2MPG to a different folder doesn't help either.
    But I figured out why VOB2MPG's FFMPEG crashes. It crashes whenever my VOBs contain DTS audio. It looks like FFMPEG can only handle AC3 and, to some extend, LPCM, although the end result with LPCM is noisy when played by DirectSound applications like Windows Media Player (unless I first extract the "noisy" audio with VirtualDub-MPEG2 as a WAV file, substitute the WAV file for the MPG's "crippled" PCM audio with MPEG Video Wizard, and export to new MPG with LPCM audio).
    The VOBs I want to merge into a single MPG file are Daft Punk/Leiji Matsumoto's Interstella 5555 animated musical DVD. I ripped the 1hr:05min-long musical with DVDFab Platinum (removes both protections and region code) selecting only DTS audio and removing the French subpictures/subtitles. MPEG Video Wizard drops audio during VOB transitions (regardless of whether it's AC3 or DTS or LPCM), hence why I'm trying to use VOB2MPG, but now I see DTS makes FFMPEG crash.
  25. Member ChrissyBoy's Avatar
    Well it sounds like VOB2MPG PRO is what you need. I should have a beta to try sometime next week. I will PM you.
  1. Problem with VOB2MPG - OverflowException error
    By Rod.G in forum SVCD2DVD & VOB2MPG
    Last Post: 31st Mar 2011, 05:04
  2. Need help with VOB2MPG. Error Message.
    By marcos77 in forum SVCD2DVD & VOB2MPG
    Last Post: 18th Sep 2010, 14:53
  3. VOB2MPG 3.0.060 Error
    By SWBisbee in forum SVCD2DVD & VOB2MPG
    Last Post: 22nd Sep 2009, 09:41
  4. VOB2MPG Pro V3.0.0024 error
    By SWBisbee in forum Newbie / General discussions
    Last Post: 3rd May 2009, 16:23
  5. VOB2MPG 2.5 install error
    By stewiegriffin711 in forum Newbie / General discussions
    Last Post: 7th Jul 2007, 16:27
