VideoHelp.com Forum
    I want to find a simple C++ source code that open a video file, and save the frames to files or better to a buffer, so that I can process a frame at a time. I don't care the procedure be done realtime. Please help me because I am lost!
  2. Mod Neophyte Super Moderator redwudz's Avatar
    You would likely get more answers in our programming forum. Moving you.
    And welcome to our forums.
  3. Member ChrissyBoy's Avatar
    Is there not a simple C++ code?Do I necessary have to use DirectShow?
  5. It depends on the video. Without directshow it is your task to decompress the video. For mpeg2 you could use the mpeg2lib.dll. For avi you can use the avifil32.dll...
    and for yuv ?
    i have to use fourcc ?
  1. Replies: 5
    Last Post: 5th Oct 2010, 16:26
  2. Replies: 0
    Last Post: 6th Jul 2010, 10:52
  3. Replies: 9
    Last Post: 20th May 2009, 15:00
  4. Switching inputs on a frame grabber
    By ftw667 in forum Capturing
    Last Post: 11th Aug 2007, 11:47
