I have Adobe Premiere Pro v7.0. I have looked on the Adobe site and cannot even find that version. I found the version 1.5 and 2.0. In any case, I am considering moving up to a high def camcorder in the near future, but I won't do it if my Pro v7.0 doesn't have an update for handling HDV. Does anybody know if there is an update for editing and saving HDV for Pro v7.0?
Thread: Adobe Premiere Pro and HDV
Guest
Adobe Premiere 7.0 is the same base program as Premiere Pro 1.0.Originally Posted by rspunches
The original Premiere ended with Version 6.5.
Premiere "Pro" was a rewrite targeted at XP and DirectShow API back around 2003. V1.0 (aka 7) was considered buggy in the day. Since then v1.5, 2.0 and now CS3 have been the update path.
HDV didn't exist in 2003
Support for HD project resolutions came with v1.5 (2004)
Support for HDV format import began with v1.5.1 (2005)
Native HDV project support was introduced in v2.0 (2006)
You can probably create an uncompressed 1440x1080 project format and decompress HDV externally for V7 but it will be very slow to edit.
Exporting HDV with Premiere Pro 2
By HDVth in forum Camcorders (DV/HDV/AVCHD)Replies: 8Last Post: 9th Mar 2011, 15:41 -
HDV and Adobe Premiere Pro CS 2 or 3
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 5Last Post: 30th Sep 2007, 05:40 -
sony hdr-sr1 & adobe premiere elements 3-can't seem to get HDV to open
By sergv in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 1st Apr 2007, 01:31 -
What happened to scene detection for HDV capture in Adobe Premiere Pro 2.0?
By rcgrabbag in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 22nd Dec 2006, 21:37 -
HDV comes to Premiere Pro
By c0r3file in forum Latest Video NewsReplies: 0Last Post: 22nd Sep 2004, 01:12
Statistics
Newest guides
Latest tool updates
New media comments
