I had that problem long time ago, I tried to reinstall WMP and codecs from Microsoft without success
I fixed that problem this way :
1) I removed all codecs packs, including ffdshow and similar
2) I used Codec Sniper to delete everything, and I mean everything
3) restart the computer
Of course, by this time nothing works at all
I started to install :
1) Koepi Xvid
2) Fraunhofer Mpeg Layer-3 Codec
3) AC3-ACM Codec
If you play some exotic formats you must install the respective codec. Then to be able to play Mpeg Streams and WMV :
1) Reinstall Nero ( fix installation ) because it uses Nero Showtime which is good and has the right codecs for MPEG, i.e., it will restore all needed codecs for Mpeg. Or use Power DVD if you want to
2) Reinstall WMP latest version
At this point you have a fresh new codecs installation as if it was a Format C:
I made this in several computers with playback problems, it's safe. Most of the problems are due to codecs conflicts, and all that packs that only are useful to ruin a computer
Hope this helps
Burning some WMV and MKV files to play on a DVD Player
By marnisper in forum Newbie / General discussionsReplies: 4Last Post: 7th Oct 2011, 09:24 -
Cannot play wmv files?
By capman21 in forum Newbie / General discussionsReplies: 1Last Post: 25th Jan 2010, 21:18 -
Converting wmv files to play in Quicktime
By gombik in forum Video ConversionReplies: 4Last Post: 3rd Sep 2009, 09:11 -
Can't play wmv files with windows media player 10
By GLE3 in forum Software PlayingReplies: 1Last Post: 2nd Sep 2009, 20:04 -
I am not able to play any wmv files. Could anyone please help?
By Gameshow Host in forum Newbie / General discussionsReplies: 16Last Post: 21st Dec 2007, 18:40
