VideoHelp.com Forum
  1. I'm trying to figure out how I can rip only certain audio channels from a DVD movie's Dolby Digital 5.1 soundtrack. I know DVD2AVI can convert the entire mix to a .wav file, but I want to only rip the left and right channels of the 5.1 soundtrack (i.e. not the center channel or rear channels).
    I've had a difficult time finding any tools to accomplish this task. I'm hoping someone here can point me in the right direction. Thanks!
    DVD-Dude
  2. Mod Neophyte Super Moderator redwudz's Avatar
    Someone with more experience with that process can probably give you more help. But I can tell you if you just rip the left and right, you may not have any dialog, as that's usually in the center channel. If you just want most sound effects and the music, left and right will work.
    A few threads:
    http://forum.videohelp.com/topic334527.html or maybe this: http://www.videohelp.com/oldguides/virtualdubaudio
  3. Always Watching guns1inger's Avatar
    Have a look at Ac3Tool or Hypercube Transcoder
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  4. Member Noahtuck's Avatar
    DVD Audio Extractor will rip 5.1 DD & DTS to 6 separate wav files.
    Originally a member since 2001, LONG LIVE TARAN's!!!
  5. Member Cornucopia's Avatar
    Audio file sizes are never that big compared to video, so the time to rip (especially Harddrive->Harddrive) isn't going to take that long. Why not just rip all the channels and then keep/save/process the ones you want.
  6. Tried DVD Audio Extractor... works perfectly! Thanks!!
  1. Replies: 3
    Last Post: 8th Jul 2011, 19:30
  2. Wave Files in MKVs
    By Bugmenotty in forum Blu-ray Ripping
    Last Post: 11th Dec 2009, 15:24
  3. Replies: 1
    Last Post: 28th Oct 2009, 16:58
  4. rip dvd folder and keep both audio channels ???
    By hulinning in forum DVD Ripping
    Last Post: 16th Feb 2009, 11:43
  5. Turning DVD chapters in to MP3 or wave files
    By ericshogan in forum DVD Ripping
    Last Post: 8th Aug 2007, 16:03
