Is a Panasonic VDR-D100 DVD Camcorder With 30x Optical Zoom a good Camcorder?
http://cgi.ebay.com/ws/eBayISAPI.dll...em&rd=1&item=1 ...![]()
Results 1 to 10 of 10
Depends if you only want an instant DVD and don't care to edit. Editing is possible but a hassle with quality drop.
I prefer MiniDV format.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
I will be using a mac for the editing
The editing machine isn't the issue. If you use an mpeg-2 native editor such as Womble, and keep you edits simple, then you can minimise the quality loss by minimising the re-encoding required. If you use an editor that decompresses the mpeg-2 video to the timeline then the whole video will be re-encoded.
I will be using iMovie 08
Unfortunately, in typical Apple fashion, the iMovie page is all glitz and no substance. Yes, it will import and edit mpeg-2 video. Will it do so without loss ? Probably not. That said, if you keep the bitrate high enough, said loss may be un-noticeable to most viewers.
I need a AC adaptor for PANASONIC PV-GS39.
AC adaptor PV-DAC14D.
I need 2 mini dv head cleaners.
Is a PANASONIC PV-GS39 a good Camcorder?
http://cgi.ebay.com/ws/eBayISAPI.dll...em&rd=1&item=1 ... amp;ih=004
Check their best ratings and compare. The PV-GS39 did Ok.
http://www.camcorderinfo.com/ratings.phpRecommends: Kiva.org - Loans that change lives.
I now need imagemixer for mac
Panasonic VDR-D100 DVD Camcorder for mac
By crocker5731 in forum MacReplies: 9Last Post: 29th Sep 2007, 22:11 -
Just got a Panasonic VDR-D105 DVD Camcorder, im looking to make DVDs
By Vizom in forum Newbie / General discussionsReplies: 1Last Post: 18th Feb 2007, 14:54 -
panasonic VDR-D100 need hlp really quickly please
By butters88 in forum Newbie / General discussionsReplies: 1Last Post: 24th Jan 2007, 16:41 -
TUTORIAL: Capturing from Panasonic VDR-M30 DVD-RAM Camcorder
By Specialist in forum CapturingReplies: 1Last Post: 5th Dec 2003, 11:43 -
Panasonic VDR-M30 DVD Camcorder
By scamp2032 in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 24th Nov 2003, 21:04
