Hi,
A friend burned some files on a CD-R for us, some short videos from a vacation.
The files are MVI files, with the WMP logo on them, and when I click on them to play, I get the following error/message from WMP:
Windows Media Player encountered an unknown error. This can occur when another program or operating system component encounters a problem but does not communicate the nature of the problem to the Player.
C00D11CD: Unknown error
Windows Media Player encountered an unknown error. This can occur when another program or operating system component encounters a problem but does not communicate the nature of the problem to Windows Media Player.
Error ID = 0xC00D11CD, Condition ID = 0x00000000
Also, a couple times trying to view the files in Explorer, my system hung pretty good. Then the drive letter looked real strange, something I never saw before, a different name for it. Had to reboot to get back the original drive letter.
Any ideas? Thanks for your time,
patmac
Thread: Newbie MVI File Problem
If Windows Explorer comes upon a format it can't read, or what it thinks is a corrupted file, it can lock up like that.
I'm not familiar with the format. You might drop one into Gspot 2.70 and see what it says. WMP is not a very versatile player. You could try VLC as it will play about anything.
I would make a copy of one and rename the extension .AVI and see what happens. If it's from a still camera, it could also be a MJPEG or a MOV format. Gspot may tell you.
redwuz,
No wonder I'm a newbie. I pulled one of the files into AVIcodec I had from a long time ago, and it's a MJPG file(motion JPG), with a .avi extension. The movie did come from a still camera, as you said. I saw the "MVI" which turns out to be part of the name of the file..duh.
Since it already has a .avi extension, what should I do now?
Maybe I'll download VLC and try that, and still wait for any other ideas from you.
Thanks, and sorry for the a "duh".......
Try VLC first. The problem with Explorer is not good, though. If it locks up, you may have some messed up files. Usually if it can't read a file, it just calls it unknown. I'm assuming when you mention the 'WMP logo' you mean the file association. You can change that as WMP seems to have a problem with them.
And what do you want to do with these files, besides play them?
SUPER can convert them fairly easily to a different format, as can several other programs.
VLC worked. I only wanted to view these files, so it's good. If I ever get time I may try to do something with them in order to send them to family members. Regarding the Explorer thing, I know it's a bit of a side bar here in this forum, I've posted elsewhere about it, and so far only have received suggestions about defragging and running ATF's Cleaner. Thanks for your help.
MVI from Canon camera file to MPEG2 dvd,
By harrisonford in forum DVD RippingReplies: 3Last Post: 9th Sep 2011, 23:50 -
VHS to File Conversion Newbie
By gk_terato in forum CapturingReplies: 5Last Post: 7th Jun 2011, 21:18 -
Convert MVI to AVI or MP4?
By Rose_Queen in forum Video ConversionReplies: 1Last Post: 8th Sep 2010, 10:56 -
.mvi clip wont play in Windows Media Player
By NP11073 in forum Newbie / General discussionsReplies: 0Last Post: 29th Nov 2008, 07:52 -
Rush and MVI format discs.
By dphirschler in forum Latest Video NewsReplies: 1Last Post: 14th Jun 2007, 09:39
