VideoHelp.com Forum
Poll: How often do you physically clean the inside of your computer?
Be advised that this is a public poll: other users can see the choice(s) you selected.
Results 1 to 30 of 33
  1. Member yoda313's Avatar
    So how often do you open your computer and blow out the dust? I admit almost never. Are you a neat freak in that respect?
  2. Member ntscuser's Avatar
    You left out "When there's so much dust inside the fan(s) stop turning"
  3. Member Bulldog57's Avatar
    hay yoda313
    I blow the box out about every 3 month it helps to keep it cool.
    Bulldog57
  4. Member edDV's Avatar
    After years of computing in low dB rooms, any change in "whirr" sound indicates dust buildup on fans.
    When you open it up, you are shocked at the mess in there. Use a plastic vac head and don't overspin fans. I've learned to jam the fan before applying suction. Moistened Q-Tips get the bulk off fan blades. Don't forget the front filters. Most don't know they exist.
  5. I get very little dust inside my computers, thanks to the thick wad of cat fur that collects on the outside air intakes. It seems to block the finer particles. I just peel off the fur whenever I notice it, monthly when the computers are on 24x7. I do vacuum the insides at least once a year.
  6. Member Marvingj's Avatar
    I used a mini-vac and a small can of air. But I have to be careful.
    http://www.absolutevisionvideo.com
    BLUE SKY, BLACK DEATH!!
  7. Member Epicurus8a's Avatar
    I'll clean it if I open the box and notice it's dirty. ...every 9 months or so.
  8. Member Soopafresh's Avatar
    ed said -
    Right you are.
  9. Renegade gll99's Avatar
    No pets in the house except fish but they are piranhas so don't think we're defenceless.
    With canned "dust-off" the whole inner case maybe once a year but the cpu fan/heatsink and power supply about every 3 months.
  10. Member Nitemare's Avatar
    Never
    Even a broken clock is right twice a day.
  11. Member Soopafresh's Avatar
    I opened up a server at a client site, and this motherboard had more dust on it than an ancient Egyptian tomb (or a Wham! record).
  12. Mod Neophyte Super Moderator redwudz's Avatar
    A couple of times a year or whenever the temps seem to be a little higher than normal. I use a vacuum and canned air most times, followed by a few swipes with a damp cloth on the interior flat surfaces.
  13. Member Dv8ted2's Avatar
    I clean it out once or twice a month. It ensures proper air flow and keeps things from overheating.
    Believing yourself to be secure only takes one cracker to dispel your belief.
  14. Member gadgetguy's Avatar
    About 4 times a year. I use some combination of vacuum, canned air, q-tips, and dust cloth. I also pull and reseat my cards and cables while I have it open.
    Buy My Books
    Whenever it starts to look like Halloween inside.
    Then if Halloween is within the next 11 months or so, I leave it 'till after Halloween.
    I haven't learned that 'dust' (or vacuum) is also a verb.
    Really, about quarterly with the vac mini-brush. Cool tool! But what's up with 'over-spinnin' the fan???
    My PC don't get much dust inside because a pair of powerful delta fans (120mm, 235CFM each) sucks most of them out. I do check once in a while to clean it out.
    I did get a free "non working" PC that worked fine after a bit of TLC:
    http://i126.photobucket.com/albums/p...m/DSC01716.jpg (inside PC)
    http://i126.photobucket.com/albums/p...m/DSC01720.jpg (CPU heatsink with fan removed)
    http://i126.photobucket.com/albums/p...m/DSC01719.jpg (power supply gut)
    yeah very messy. That PC is only 2 years old BTW so no idea how it got so dusty.
  17. Mod Neophyte Super Moderator redwudz's Avatar
    I can see why it's 'non-working'. Thanks, that's a classic.
  18. Member
    I clean mine about once a year and it's pretty dirty, though not as bad as the picture.
    A couple of PC magazines I subscribe to had interesting articles about cleaning PC's within the past 2 years. They both agreed that one should not use a vacuum on the insides, because of the possibility of a static discharge. What they recommended was taking it outside and blowing out the dust with canned air. They also sugested making your own filters out of Swiffer or similar dust cloths and taping it over the vents, if your PC does not have its own filters. Of course these would have to be replaced every few months.
    The wierdest thing was cleaning the keyboard. One article suggested running it through the dishwasher on gentle cycle, using a teaspoon of liqiud dishwasher soap, without heated dry. Then air-dry upsde down for 3 days. I guess this is in the event you spill a sticky drink on it or need to decontaminate it, and the alternative is to throw it out. Doesn't seem safe to me, although I've heard that hospitals buy keyboards specially made to survive this kind of cleaning.
  19. Member edDV's Avatar
    Eww! Take it outside and use a mask. Resist the tempation to use the power washer.
    Originally Posted by usually_quiet
    ...although I've heard that hospitals buy keyboards specially made to survive this kind of cleaning.
    I'd buy one with a "dishwasher safe" sticker.
    I used a shop vac to suck those out. Yeah I know static electricity but I'm not wasting money on canned air =P
    And there are sealed spill proof keyboard, check eBay for silicone (sp?) keyboard. Small and full size and in many colors. Also good for one with short temper and likes to pound on keyboard.
    Lastly: here's another air filter idea: if you are female or live with female, save any old nylon stocking and use it for screen. Probably a lot cheaper than swiffer.
    3 Halloweens in the same pc. Whatsa' problem???
  22. Member
    Just toss in a few seeds, and water regularly.
  23. Member
    Time to run the 'found new hardware wizard'?
    pc-Cillin?
    CHIA PC?
  24. Member yoda313's Avatar
    Those must also be defective fans - two of them didn't get rid of the dust!
  25. Member gadgetguy's Avatar
    I would be concerned about using a swiffer for a filter. I'm afraid it would limit the air flow too much and be almost as damaging as the dust.
    Buy My Books
  26. Member
    FANS???
    I thought those two things were the FILTERS!!!
  27. Member yoda313's Avatar
    FANS???
    They have rotating blades from the looks of it. I assumed they were fans.....
  28. Member
    Probably once a week, because my computer side is always open. Since my computer is kind of old it gets hot on rendering in Premiere. So i have i open always with a huge fan blowing in it. lol. ghetto... But it keeps it from overheating. I definintely need a new computer. I always have a can of compressed are around and blow it out once a week probably. Im sure the dust is just floating back in since its always open, but oh well.
  29. Member MeDiCo_BrUjO's Avatar
    Twice a year, usually when I change a card or something else inside the computer.
    I take it outside and use the vacuum in reverse... that blows EVERYTHING away!.
    1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!!
  30. When I change parts inside it.
  1. WDTV Live needs to be physically disconnected when it couldn't play a file
    By tigerb in forum Newbie / General discussions
    Last Post: 23rd Jan 2012, 03:50
  2. Replies: 0
    Last Post: 5th Jun 2010, 06:47
  3. Fedron to clean the inside of a VCR?
    By Fryster in forum Restoration
    Last Post: 16th Dec 2009, 11:51
  4. Replies: 8
    Last Post: 5th Oct 2009, 19:48
  5. Reading a physically cracked dvd
    By Starman* in forum Newbie / General discussions
    Last Post: 16th Mar 2008, 13:00
