VideoHelp.com Forum
    Hello, A newb question here: I followed the hack instructions perfectly and the player reacted the way it was described in the hack instructions exactly except for the fact that it STILL won't play other region dvds! Any advice at all will be greatly appreciated, thanks!
  2. Member Krispy Kritter's Avatar
    Quite often new versions of a player are locked to prevent the codes from working. You also need to ensure you are using the correct codes, sometimes players from different regions use different codes.
    Most Sony and JVC units are often locked and don't use codes at all.
    Google is your Friend
  1. Philips DVP3560 - region code hack question
    By Malsperanza in forum DVD & Blu-ray Players
    Last Post: 5th Nov 2011, 12:15
  2. Euroline DVD100 DVD Player Region all region code/hack?
    By mjgjhb in forum Newbie / General discussions
    Last Post: 21st Jul 2011, 09:26
  3. Sony DVD Recorder RDR-GX350 - Region Hack Code Required.
    By Teac23 in forum DVD & Blu-ray Recorders
    Last Post: 2nd Sep 2009, 03:19
  4. region code for Sony RDR GX355
    By daleacn in forum Newbie / General discussions
    Last Post: 19th Feb 2009, 12:40
  5. how do change Sony RDR-HX680 region code
    By kartul in forum DVD & Blu-ray Recorders
    Last Post: 11th Dec 2008, 14:58
