I recently used the DVD region code hack for the LG RH 278H from http://www.videohelp.com/dvdhacks/lg-rh277h/8198, and it worked. However, while doing this I accidently changed some other "values" in OP1, OP2, OP3, etc. Can someone send me or post the exact values of all the OP1, OP2, etc? Thank you.
Results 1 to 15 of 15
Thread: LG RH 278H original settings
I too have this problem--- Unfortunately LG customer service was unable to help me...! Because I changed some of the other options, it seems that my DVDr/VCr will not longer recognize my antenna connection. Many thanks in advance to anyone who can help!
Who can help me for the original OP1 , OP2 etc.settings for the LG-RH277(H)? I have change one of them and now when i switch the recorder off there is no clock display on the screen.
Jakobus,
Do you have the original settings for the other options (other than 1 & 2)? If so, would you mind sharing them?
Many thanks in advance for your post!
vktrip,
I have a LG-RH277 dvd recorder en my settings for OP1 , OP2 and OP3 are not orginal at this time.I don't now if the settings for the LG-RH278H are the same as for the LG-RH277.
greetings
i've just done the same thing on my brand new player, now i've lost the led display on the player, it's all garbled. please help!
also the idiot that posted the hack should remove it.
also found this??? http://ifndef.altervista.org/index_eng.html
ok, i'm back to normal again, without the hack, these are my settings, hope this helps.....LG RH277H
OP1-DA
OP2-B0
OP3-03
OP4-70
OP5-0E
OP6-AF
OP7-47
OP8-02
OP9-00
OPA-00
Flexagon,
Are these settings for the RH277 ?
And thanks for the link.
jakobus, these are the default settings on my RH277H, dont know if the "H" at the end makes a difference or not?
Thanks flexagon,
Everythings works fine now.The 'H"at the end did't make a difference
Well, the hack should work. The problem is that if you're not careful, you can change some of the other OP codes. However, there's nothing stopping you from adding a note warning people of that hack ...
The idea is to change bit 7,6,5 on OP6 so that all three are 0.
In your case, you go from:
AF: 1010 1111
to
8F: 1000 1111
This is how I made my previous generation LG (780) to all region.
I made mine lg rh 277 region free using this hack.
However, now my timer recording feature does not work.
I think I may have changed the last parameter by mistake.
Can someone post the original parameters?
Also, has anyone else had this problem?
thanks,
buckint@gmail.com
Flexagon,
Are you sure that your settings posted above are the original ones?
I have different settings in positions 1,2,3,5,7, and 8.
thanks,
buckint@gmail.com
Hallo I accidently pushed F8 in po06 insted of 8F. And now I cant get no signal to the antenna and DVD throught the hdmi cabel but i can se the things I recordet earlier throught a scart. And I cant get into the code hack menu couse I have no visiol. What to do?
guys, need help URGENTLY. I tried to change the opcodes on my LG RH277 yesterday, however accidentally i have changed the opcodes for the remote control, so now it is completely blocked and i cannot access the CLEAR key to change them again. Does anyone know if there is a way to get into the Options menu without the remote control?
I'm really at a loss here, it's such a shame to see my 222 euros go to waste! the lg service centre here in cyprus don't seem to have a clue either.
How to configure Handbrake to keep original video settings while adding sub
By ngngokkiu in forum SubtitleReplies: 3Last Post: 8th Mar 2012, 12:34 -
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
Using original menu
By gouletjo in forum Authoring (DVD)Replies: 5Last Post: 16th Feb 2010, 19:06 -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 12:52
