VideoHelp.com Forum
    hi,
    Can you please provide with me some online material having information regarding MPEG-1 compressed video format with detailed information abt start code bits and header info .
    My objective is to read some MPEG-1 compressed video file using C code . so i need to know the exact bit sequence , metadata bits , start code etc in order to read video file .
    However , is there any other way i can achieve my objective.
  2. Mod Neophyte Super Moderator redwudz's Avatar
    Try this site: http://bmrc.berkeley.edu/frame/resea..._overview.html At the bottom of that page are more links.
    And if you are looking for MPEG-1/VCD info: http://www.videohelp.com/vcd Down at the bottom of that page are also some links to more technical information.
    And welcome to our forums.
    Thanks for replying to my query .
    Well i went throught that site and it proved to be helpful .
    But can i get the " exact binary bit order format" of an MPEF-1 video compressed files .
    because If i know wht bits(and how many) represent header info and wht represents compressed data i can easily read MPEG compressed data bits using C and according modify their value..
    ... plz provide any relevant info for the above query .
  1. Problem converting from MPEG Program Stream to Transport Stream
    By vivajam in forum Newbie / General discussions
    Last Post: 24th Jan 2011, 04:40
  2. Is there a tool to reveal a DVD's info, such as Bit stream mode...
    By takearushfan in forum Newbie / General discussions
    Last Post: 31st May 2010, 23:13
  3. Replies: 0
    Last Post: 27th Nov 2009, 04:40
  4. Which video format has the best about everything ( quality, bit rate...) !?
    By coxanhvn in forum Newbie / General discussions
    Last Post: 3rd Sep 2008, 21:02
  5. MPEG Transport Stream Format
    By Hoggle in forum Programming
    Last Post: 26th May 2007, 20:03
