I am not sure where to post this, Baldric feel free to move this where you feel appropriate.
I was wondering if anyone has ever burned a Powerpoint presentation to a DVD disk so that it can be played on a standalone player, or possibly a CD. When I Google I come up with lots of hits, but figured that someone here probably has a tool that works well. Experience is best. Thanks
I have to confess that I have looked for software to so this very task and failed hopelessly.
In the end I used Photoshop to create images and then spliced them together as a slideshow using Vegas - although any image editor (even paint) and any slideshow creator would do the job equally well.
The only other way that springs to mind it to create your powerpoint and then run the slideshow with the TV out from your graphics card hooked up to a DVD recorder. You might then need to rip the DVD and edit the video but it would at least give you something to work with.
Equally Camstudio might do the trick - instead of outputting to a DVD recorder CamStudio will grap the screen as a movie ready for editting. -
Take a look at this thread, it discusses this issue at length.
It is also the 6th hit you get when you do a search in the forums for "powerpoint to DVD". The search function is not to be underestimated!In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. -
Wondershare Software has a converter to do this very thing. They are not listed in the tools section but a google search brings them up.
Giveawayoftheday.com gave the Flash to DVD converter away a few weeks ago. I d/l it but I have to admit I have not tried it yet. Looks promising enough though.
Of course this probably doesn't help you any but I hope it might.
--dES"You can observe a lot by watching." - Yogi Bera
http://www.areturningadultstudent.com -
I used the Wondershare software to create the opening credits of a friend's wedding video. It helps me create titles and animations that would have not been possible because I do not have the program to do it. And I downloaded it from giveawayoftheday.com
@ Apriz (and the other aliases you are using) : if you want to advertise your products, and truly stand by them, pay the webmaster, Baldrick, for the privilege. Your products will get due space, and you will help support this site instead of filling it with unsolicited noise.
Read my blog here.
Thanks all, I appreciate your input. Lots of good info and suggestions. Gunslinger... good point, I agree. Spam isn't needed in this forum.
how can i convert a powerpoint presentation and put it on dvd
By shashgo in forum Newbie / General discussionsReplies: 7Last Post: 8th Oct 2009, 03:14 -
Powerpoint Presentation to Video/DVD Software
By Nasho23 in forum Newbie / General discussionsReplies: 2Last Post: 10th Apr 2008, 23:59 -
How can I Put PowerPoint on a DVD?
By jrhx in forum Authoring (DVD)Replies: 35Last Post: 26th Jun 2007, 13:07 -
DVD with videos and Powerpoint
By RobertUSM in forum Authoring (DVD)Replies: 6Last Post: 15th May 2007, 10:40
