My apologies if someone has already answered this question. I have searched the forums carefully and was not able to locate an answer.
I have a collection of DV tapes going back to 1998. I have captured each tape into a single DV AVI file over the past few years - primarily as a backup. So I now have 30 or so large 8-17GB DV AVI files.
I would like to split these into smaller AVI files using the Time Stamp in the DV file.
Ideally I'd like to point a program/utility at my single TAPE0001.AVI and generate multiple scene files based on the Time Stamp e.g. 1998_06_04_14_22_00.AVI, 1998_06_04_15_33_00.AVI, etc.
I started to recapture the files using WinDV to do this, but unfortunately the older tapes are now close to 10 years old and some of the footage is choppy (I guess the tapes have deteriated).
Could anyone recommend a utility that would do this? I don't mind paying for a commercial solution, I just want something that's reliable and can be run in batch mode.
I would recommend DVDate by Paul Glagla http://paul.glagla.free.fr/dvdate_en.htm
I have been using DVDate for all things DV for years and it has not failed me.
It can (quickly) create a scene file from your avi file and then with that you can split the avi into scenes (by datecode).
It is free, small (1.5MB), can run from a flash drive (i.e. doesn't need to be installed), and is easy to use. Do I sound like I like DVDate? I do.Michael
phototools.co.nr
Wow! DVDate has an amazing array of features.
I figured out I can do what I want in a two step process - first split the AVIs by scene to a new output folder, then 2nd rename the AVI's using the time stamp to the format required - all with DVDate.
The DVDate Developer also has a great utility called ImageGrab that can be scripted to generate thumbnails from the AVIs - which works like a charm.
It's going to be so much easier to catalog and integrate this video into some home DVDs using these tools!
Many, Many Thanks!
Richard
merge multiple avi to 1 single file
By carlos28355 in forum Newbie / General discussionsReplies: 16Last Post: 2nd Oct 2010, 20:11 -
Multiple scenes in a single AVI file? How to separate...
By kelemvor in forum Authoring (DVD)Replies: 1Last Post: 27th Jan 2007, 01:26 -
How to split Camcorder AVI movie to multiple files?
By singkarak in forum Newbie / General discussionsReplies: 3Last Post: 29th May 2004, 01:23 -
Multiple AVI Files into a single DVD
By bappida69 in forum Video ConversionReplies: 5Last Post: 1st Aug 2003, 22:25 -
How to Encode multiple split AVI files into a single MPG ?
By roli_bark in forum Video ConversionReplies: 10Last Post: 15th Mar 2003, 03:40
Statistics
Newest guides
Latest tool updates
New media comments
