VideoHelp.com Forum
  1. Hi,
    Is there a dvd recorder(no hdd) unit that has spare drive replacement parts available.I want to record 24/7 365 days for cctv use so when the drive fails the parts can easily changed.
  2. If you look at eBay prices for non-hdd dvd recorders in general, the prices are about $80. You might be better off replacing rather than trying to repair at that low a price.
    I have an invalid friend who had a burglary problem, so I helped him set up a cctv system with a dvd recorder just like you are suggesting ( without a hdd ) at first, then we tried a hdd recorder, then a dedicated surveillance hdd dvr. The non-hdd dvd recorder was a Panasonic DMR-ES10. It had the advantage of recording to dvd-ram which allowed recording and reviewing at the same time but the dvd-ram still needed to be replaced every so many hours.
    The dedicated surveillance dvr is a much better solution for the following reasons
    1) it can capture multiple channels at full D1 resolution with sound
    2) it has a grid system for motion sensing ( not in the camera ) that activates recording of each channel only when the active grids see motion so you do not record lots of "nothing happening" time.
    3) it can offload video to a usb drive in avi format for archiving.
    4) in many units the hdd can be removed just by unplugging from the front panel for upgrading to a larger drive.
    5) many are triplex in that you can monitor, record, playback or view via Ethernet simultaneously.
  1. Replies: 4
    Last Post: 16th Jun 2011, 18:28
  2. DVR/CCTV and Dazzle
    By PDX Ghost Hunter in forum Capturing
    Last Post: 17th Nov 2010, 11:03
  3. Video on iPhone for CCTV
    By nick.chetav in forum Portable Video
    Last Post: 3rd Jun 2010, 01:46
  4. Searching for Specific DVD Recorder Device
    By SupaDupaMonkey in forum DVD & Blu-ray Recorders
    Last Post: 27th Jul 2009, 16:58
