basicly what is happening is i get the audio encoded fine but it doesnt seem to really process the video and if i play the WMV i see an error about this DLL file in the window where the video should be but the audio keeps on playing.
22:24:28 Copyright: Done with AutoMKV! 0.89
22:24:28
22:24:28 Warning: Encoder failed to retrieve duration attribute from source plug-in.
22:24:28 .
is in the log and related to that file but i have the dll in the default folder.
Should be an AVISynth plugin. Check the AVISynth script that it creates and see if it specifies a path for the dll. If not then it would need to go in the AVISynth plugin dir.
i fixed it, i found i was missing some DLLs from some kinda C++ libs so i DLed them and put them into my system32 directory and all was well.
Virtualdub Error Message - Failed to load FFmpeg.dll
By SOSmkII in forum Video ConversionReplies: 5Last Post: 6th Feb 2012, 07:14 -
Failed to load subtitles
By Basd in forum SubtitleReplies: 1Last Post: 7th Oct 2011, 16:06 -
Computer keeps trying to load some weird ntload.dll file
By jyeh74 in forum ComputerReplies: 40Last Post: 28th Dec 2009, 08:41 -
enc_aacplus.dll error while using AutoMKV
By nx01rules in forum DVD RippingReplies: 3Last Post: 15th Oct 2009, 04:24 -
Changed Names/Locations - Now "Failed to Load; file doesn't exist
By jeffc4442 in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 22nd Sep 2007, 01:10
Statistics
Newest guides
Latest tool updates
New media comments
