Hey,
I am looking for software online that I can download and use with my 2 video cameras connected to the computer to mix them as they are streaming into the computer. Also I would like to be able to set a fade in so that when i begin recording the camera will automatically fade in. The mixing I would like to have different options for transitions.
thanks,
Chase
Thread: Live 2 camera mixing software
It is normally being done during 'editing' on a material that is already dumped to your hard disks, not on a 'live' feed
They did it that way in 70's with hardware mixers, and even now it is done with hardware during live transmissions and such (albeit it is controlled by software).
Short from any studio-specialized software (that probably works with specific hardware only) I doubt you'll find standalone program for a Windoze based home PC.
Maybe some plugins etc for half-pro soft is out there, I dont know, but still - you should do it when youre editing your stuff, not when youre feeding your PC with live feed from DV (or from tape).
One way
http://www.bhphotovideo.com/c/produc..._Switcher.html
This is for live event multi analog cam mixing into a capture card. Contains a frame sync.
Another way. I need to try this.
http://www.varasoftware.com/products/wirecast/
yeah, seems like cool gadgetOriginally Posted by edDV
just downloaded it, will try it at home
Live Video Mixing with Flash Media Live Encoder
By fuggles7 in forum Video StreamingReplies: 0Last Post: 7th Apr 2012, 13:08 -
Live HD video mixing - which software/Hardware ?
By Edwoo11 in forum Software PlayingReplies: 0Last Post: 13th Apr 2011, 15:10 -
Help with finding video mixing software
By jackthedj94 in forum Software PlayingReplies: 8Last Post: 26th Jun 2009, 05:27 -
Camera suggestions for live streaming
By jbaugh in forum MacReplies: 6Last Post: 14th Dec 2008, 19:06 -
Mixing 5.1 - What Software Should I use?
By scottrwn98 in forum AudioReplies: 0Last Post: 11th Sep 2007, 15:11
