I recently sent my laptop off to be repaired (replaced heatsink and fan.) But now I got it back my video capture device (Plextor M402U) doesn’t work on it. Every bit of software that I could capture with it crashes. Is there anyway I can find out how to fix it?
It still works on my PC so its not the device.
Also my mini DV camcorder still works.
Edit. It appears to be the USB extension cable that i'm using for some reason. Still doesn't explain why it use to work on the laptop and still works on my PC. (through the same USB extension cable)
Thread: Capturing Problem.
Try uninstalling the original software that came with the device , then uninstall the device drivers for it .
Reboot system , reinstall product , reboot (do not connect the device till after all this is done) .
Try the device afterwards .
Sometimes usb devices can just take a walk , for no apparent reason .
Obviously the mini dv camcorder connects via usb
Capturing problem
By Phoenix 37 in forum CapturingReplies: 4Last Post: 18th Jun 2011, 17:09 -
Capturing with firewire problem
By towarmforacoat in forum MacReplies: 5Last Post: 7th Nov 2009, 03:15 -
Problem Capturing DV with Windows 7
By monoxide77 in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 9th Jun 2009, 14:31 -
VHS Capturing Problem
By sdculp in forum CapturingReplies: 14Last Post: 12th Feb 2008, 15:08 -
DV capturing problem
By BMR in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 25th Sep 2007, 16:19
Statistics
Newest guides
Latest tool updates
New media comments
