VideoHelp.com Forum
    I am having a lot of difficulties playing this one file, encoded with h264 and vorbis in a matroska container. The only program that opens this file without any problem is ConvertXtoDVD. AVIDemux can also open it but, for some reason, the file, as well as any other h264 file I ever tried with this prog, comes up looking really fuzzy. I have been able to play other h264 files on my computer, albeit in .mp4 container. This is the first .mkv file for me. I'd appreciate any help.
    I have Haali Media Splitter and DTS x264 vfw. I also have Nero which comes with NeroAVC.
    Here is info from MediaInfo:
    Complete name : abc.mkv
    File size : 449 MiB
    Format : Matroska
    Overal BitRate : 713 Kbps
    PlayTime : 1h 28mn
    Encoded date : UTC 2007-07-13 05:26:07
    Writing application : mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55
    Writing library : libebml v0.7.7 + libmatroska v0.8.1
    Video
    Codec : MPEG-4 AVC
    Info : MPEG4 ISO advanced profile
    Bit rate : 696 Kbps
    Width : 720
    Height : 304
    Aspect ratio : 2.35
    Frame rate : 25 fps
    Bits/(Pixel*Frame) : 0.127
    Language : English
    Audio
    Codec : Vorbis
    Bit rate mode : VBR
    Channel(s) : 2 channels
    Sampling rate : 48 KHz
    Text
    Codec : ASS
    Info : Advanced Sub Station Alpha
    Following is a list of error messages that I get when trying to open the file with various apps:
    Media Player Classic
    Media Type 0:
    Video: MPEG4 Video (H264) 720x304 25.00fps
    AM_MEDIA_TYPE:
    majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71}
    subtype: Unknown GUID Name {31435641-0000-0010-8000-00AA00389B71}
    formattype: FORMAT_MPEG2_VIDEO {E06D80E3-DB46-11CF-B4D1-00805F6CBBEA}
    bFixedSizeSamples: 1
    bTemporalCompression: 0
    lSampleSize: 1
    cbFormat: 256
    VIDEOINFOHEADER:
    rcSource: (0,0)-(0,0)
    rcTarget: (0,0)-(0,0)
    dwBitRate: 0
    dwBitErrorRate: 0
    AvgTimePerFrame: 400000
    VIDEOINFOHEADER2:
    dwInterlaceFlags: 0x00000000
    dwCopyProtectFlags: 0x00000000
    dwPictAspectRatioX: 45
    dwPictAspectRatioY: 19
    dwControlFlags: 0x00000000
    dwReserved2: 0x00000000
    MPEG2VIDEOINFO:
    dwStartTimeCode: 0
    cbSequenceHeader: 124
    dwProfile: 0x00000064
    dwLevel: 0x00000033
    dwFlags: 0x00000004
    BITMAPINFOHEADER:
    biSize: 40
    biWidth: 720
    biHeight: 304
    biPlanes: 1
    biBitCount: 24
    biCompression: AVC1
    biSizeImage: 0
    biXPelsPerMeter: 0
    biYPelsPerMeter: 0
    biYPelsPerMeter: 0
    biClrUsed: 0
    biClrImportant: 0
    pbFormat:
    0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    0020: 00 00 00 00 00 00 00 00 80 1a 06 00 00 00 00 00 ...............
    0030: 00 00 00 00 00 00 00 00 2d 00 00 00 13 00 00 00 ........-.......
    0040: 00 00 00 00 00 00 00 00 28 00 00 00 d0 02 00 00 ........(......
    0050: 30 01 00 00 01 00 18 00 41 56 43 31 00 00 00 00 0.......AVC1....
    0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    0070: 00 00 00 00 7c 00 00 00 64 00 00 00 33 00 00 00 ....|...d...3...
    0080: 04 00 00 00|00 19 67 64 00 33 ac 34 e7 02 d0 9e ......gd.34.О
    0090: 84 00 00 03 00 04 00 00 03 00 ca 3c 60 c6 78 00 .........<`x.
    00a0: 5f 68 ee bc e5 34 42 63 15 84 13 08 47 4a 22 29 _h4Bc...GJ")
    00b0: 31 4a c7 26 32 12 66 88 4c 52 b1 c9 84 23 b3 45 1J&2.fLRɄ#E
    00c0: 26 29 58 c4 c2 11 c9 55 26 45 64 49 b2 25 6c 94 &)X.U&EdI%l
    00d0: 9b 92 95 b9 12 4d b2 11 59 44 11 32 88 11 12 10 .M.YD.2...
    00e0: 08 04 43 90 51 aa 4c 8a c8 93 64 4a d9 a9 37 25 ..CQLȓdJ٩7%
    00f0: 2b 72 52 6e 44 ad 8e 49 b0 82 b0 c2 61 88 20 c0 +rRnD*Ia
    NeroShowTime crashes with this message:
    Microsoft Visual C++ Runtime Library Runtime error! Program: C:\....\ShowTime.exe This application has requested the Runtime to terminate it in an unusual way.
    VirtualDubMod:
    [!] MKV: A frame of stream 1 (at 80 ms) had only a forward reference (maybe
    broken file).
    [!] MKV: A frame of stream 1 (at 40 ms) had only a forward reference (maybe
    broken file).
    [!] MKV: A frame of stream 1 (at 240 ms) had only a forward reference (maybe
    broken file).
    [!] MKV: A frame of stream 1 (at 200 ms) had only a forward reference (maybe
    broken file).
    . LOTS MORE LIKE THESE
    [!] MKV: A frame of stream 1 (at 5284080 ms) had only a forward reference
    (maybe broken file).
    [!] MKV: A frame of stream 1 (at 5284040 ms) had only a forward reference
    [!] MKV: A frame of stream 1 (at 5284240 ms) had only a forward reference
    [!] MKV: A frame of stream 1 (at 5284200 ms) had only a forward reference
    [!] MKV: Video frames seems to be weirdly ordered.
    [!] Couldn't locate decompressor for format '' (unknown).
    VirtualDub requires a Video for Windows (VFW) compatible codec to
    decompress video. DirectShow codecs, such as those used by Windows Media
    Player, are not suitable. Only 'Direct stream copy' is available for this
    video.
    DGAVCIndex, for the .h264 file demuxed with MKVToolNix, gives me this message:
    Cannot open Annex B ByteStream type file.
    try VLC player, the new h264 MKV are a royal pain
    maybe you can watch it that way
    good luck with converting it too DVD
    Thank you. I am hoping to understand the problem though. Especially if it's something as simple as installing a different codec or something.
    Make sure you are running the latest version of the splitter, and perhaps try the latest FFDShow as well.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Yep. installing FFDShow solved it. Thanks.
    I was kinda hoping not having to install this one. Oh well...
  6. Always Watching guns1inger's Avatar
    I had similar problems with ConvertxtoDVD and one AVC mkv file. Same sort of error messages. FFDShow allowed me to use FAVC to encode it instead.
  1. Replies: 5
    Last Post: 20th Dec 2011, 08:50
  2. matroska files playing problems
    By pepevideo in forum Blu-ray Ripping
    Last Post: 30th May 2008, 08:28
  3. GUI to convert Matroska (*.mkv) To AVI
    By qwerty9876543 in forum Linux
    Last Post: 17th Mar 2008, 21:38
  4. Searching for matroska/MKV Codec
    By moviebuff2 in forum Newbie / General discussions
    Last Post: 26th Dec 2007, 09:54
  5. Conveting .MKV(Matroska) to AVCHD Disc/HD DVD-5
    By carlitos287 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 13th Aug 2007, 21:22
