VideoHelp.com Forum
  1. I am in need of a video editing package that I can realtime edit .TSP files directly, I need the ability to cut out sections (commercials) then save it as a standard MPG or DIVX format. I need this all to be done with out getting the audio out of sync.
    Also, the .TSP often contain different audio tracts so I will need the program to have the ability to pick the correct audio track for the output.
    I would like this all to reside in the same package. Perferably able to do this without re-encodeing (unless saved as something like xvid, or divx ect....)
    Anyone know of a program that can do all of this.. The .tSP files are coming from a dishnetwork DVR
    Thanks.
  2. Member Soopafresh's Avatar
    Try VideoRedo
  3. Originally Posted by Soopafresh
    Thanks for the tip, however this program is limited to 15 minute segments unless you buy it..
    Here is what i found so far.
    I use the EXT2FSD to read the DVR drive in a windows system.
    PRVExplorerPro to mux/remux the video into standard MPEG
    then mpg2cut2 to remove things that need to be cut...
    All of this is freeware.
    Does anyone know of a freeware application to automatically detect comercials in video and mark them for removal.. Preferably without re-encoding.
    I looked at projectx but it is far to complicated for me.. I like it simple.
    You might also look at PVAStrumento or Kiss DTV 2 DVD
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  5. Member Soopafresh's Avatar
    Comskip is an app which can remove commercials. Not very fast, however.
  6. Member erik1958's Avatar
    Comskip can only detect where the commercials are and it can output a cutlist for many free/nonfree video editors.
  1. MPEG-2 edit/save, edit/save, edit/save... cycle
    By KZemunski in forum Newbie / General discussions
    Last Post: 26th Dec 2010, 14:55
  2. Replies: 11
    Last Post: 3rd Nov 2009, 14:32
  3. MPC cannot render some tsp's...
    By cwb in forum Newbie / General discussions
    Last Post: 22nd Sep 2009, 22:34
  4. Edit VOB files and save to dvd
    By NickyJ in forum Newbie / General discussions
    Last Post: 1st Jul 2008, 12:59
  5. Simple way to edit MiniDV footage and save it to DVD
    By jellyfear in forum Newbie / General discussions
    Last Post: 13th Apr 2008, 17:35
