I don’t know what has gone wrong. I had been using DVDStyler for a couple of weeks with only one minor problem, which was solved. It has just started to give me two errors which I cannot figure out how to fix. One is when I’m creating a motion menu, the other when I use a still menu. I’m creating a simple DVD with only one actual menu in use. The other(s) is a dummy menu(s). I reset the settings, but continued to get errors. I uninstalled it, removed remnants from the registry, reinstalled, but still get the same errors.
Please help if you can. Thanks.
I've included an image of the core settings (at the bottom). Since the command line for Jpeg2Mpeg is too long, I've included it here:
Jpeg2Mpeg command: jpeg2yuv -n $FRAMES -I t -L 1 -f $FRAME_RATE -j '$FILE_IN' | mpeg2enc -f 8 -b $BITRATE –o '$FILE_OUT' $VIDEO_NORM (I'm hoping it's something here that is causing the problem, although it would be weird since it used to work "as-is")
Here is the log for still images:
Summary:
Prepare
Generating menus
Failed
Details:
Prepare
Cleaning temporary directory
Generating menus
Generating menu 1 of 2
Prepare
Converting jpg to mpeg
INFO: [jpeg2yuv] Parsing & checking input files.
**ERROR: [jpeg2yuv] System error while opening: "C:\Documents and Settings\Louv68\Desktop\Stargate Infinity DVDs\Temp\dvd\menu0-0.mpg_bg.jpg": No such file or directory
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
Error executing of command: jpeg2yuv -n 1 -I t -L 1 -f 29.97 -j 'C:\Documents and Settings\Louv68\Desktop\Stargate Infinity DVD's\Temp\dvd\menu0-0.mpg_bg.jpg' | mpeg2enc -f 8 -b 9000 -o 'C:\Documents and Settings\Louv68\Desktop\Stargate Infinity DVD's\Temp\dvd\menu0-0.mpg_bg.m2v' --video-norm n --frame-rate 4
Here's the log for motion menus
Summary:
Prepare
Generating menus
Failed
Details:
Prepare
Generating menus
Prepare
Fix MPEG-file: C:\Documents and Settings\Louv68\Desktop\Stargate Infinity avi''s\Stargate Infinity Motion Background.MPG
DemultiplexingXXX : [audio 01 video 01] [ 0.25%]
DemultiplexingXXX : [audio 01 video 01] [ 5.12%]
DemultiplexingXXX : [audio 01 video 01] [ 10.25%]
DemultiplexingXXX : [audio 01 video 01] [ 15.12%]
DemultiplexingXXX : [audio 01 video 01] [ 20.25%]
DemultiplexingXXX : [audio 01 video 01] [ 25.13%]
DemultiplexingXXX : [audio 01 video 01] [ 30.25%]
DemultiplexingXXX : [audio 01 video 01] [ 35.12%]
DemultiplexingXXX : [audio 01 video 01] [ 40.25%]
DemultiplexingXXX : [audio 01 video 01] [ 45.12%]
DemultiplexingXXX : [audio 01 video 01] [ 50.25%]
DemultiplexingXXX : [audio 01 video 01] [ 55.11%]
DemultiplexingXXX : [audio 01 video 01] [ 60.23%]
DemultiplexingXXX : [audio 01 video 01] [ 65.10%]
DemultiplexingXXX : [audio 01 video 01] [ 70.23%]
DemultiplexingXXX : [audio 01 video 01] [ 75.10%]
DemultiplexingXXX : [audio 01 video 01] [ 80.22%]
DemultiplexingXXX : [audio 01 video 01] [ 85.08%]
DemultiplexingXXX : [audio 01 video 01] [ 90.21%]
DemultiplexingXXX : [audio 01 video 01] [ 95.08%]
Demultiplexing : [audio 01 video 01] [100.00%]
INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
INFO: [???] File C:\Documents and Settings\Louv68\Desktop\Stargate Infinity DVD's\Temp\dvd\menu0-0.mpg_bg-0.m2v looks like an MPEG Video stream.
INFO: [???] File C:\Documents and Settings\Louv68\Desktop\Stargate Infinity DVD's\Temp\dvd\menu0-0.mpg_bg-0.mp2 looks like an MPEG Audio stream.
INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [???] Found 1 audio streams and 1 video streams
INFO: [???] Selecting dvdauthor DVD output profile
INFO: [???] Multiplexing video program stream!
INFO: [???] Scanning for header info: Video stream e0 (C:\Documents and Settings\Louv68\Desktop\Stargate Infinity DVD's\Temp\dvd\menu0-0.mpg_bg-0.m2v)
INFO: [???] VIDEO STREAM: e0
INFO: [???] Frame width : 720
INFO: [???] Frame height : 480
INFO: [???] Aspect ratio : 4:3 display
INFO: [???] Picture rate : 29.970 frames/sec
INFO: [???] Bit rate : 6800000 bits/sec
INFO: [???] Vbv buffer size : 229376 bytes
INFO: [???] CSPF : 0
INFO: [???] Scanning for header info: Audio stream c0 (C:\Documents and Settings\Louv68\Desktop\Stargate Infinity DVD's\Temp\dvd\menu0-0.mpg_bg-0.mp2)
INFO: [???] MPEG AUDIO STREAM: c0
INFO: [???] Audio version : 1.0
INFO: [???] Layer : 2
INFO: [???] CRC checksums : no
INFO: [???] Bit rate : 16384 bytes/sec (128 kbit/sec)
INFO: [???] Frequency : 48000 Hz
INFO: [???] Mode : 0 stereo
INFO: [???] Mode extension : 0
INFO: [???] Copyright bit : 0 no copyright
INFO: [???] Original/Copy : 0 copy
INFO: [???] Emphasis : 0 none
INFO: [???] SYSTEMS/PROGRAM stream:
INFO: [???] rough-guess multiplexed stream data rate : 7074400
INFO: [???] target data-rate specified : 10080000
INFO: [???] Setting specified specified data rate: 10080000
INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
INFO: [???] New sequence commences...
INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [???] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [???] Scanned to end AU 2477
INFO: [???] STREAM e0 completed @ frame 2477.
INFO: [???] STREAM c0 completed @ frame 3443.
INFO: [???] Multiplex completion at SCR=7439652.
INFO: [???] Video e0: buf= 227793 frame=002477 sector=00018868
INFO: [???] Audio c0: buf= 640 frame=003443 sector=00000655
INFO: [???] VIDEO_STATISTICS: e0
INFO: [???] Video Stream length: 38043011 bytes
INFO: [???] Sequence headers: 166
INFO: [???] Sequence ends : 1
INFO: [???] No. Pictures : 2477
INFO: [???] No. Groups : 166
INFO: [???] No. I Frames : 166 avg. size 34242 bytes
INFO: [???] No. P Frames : 660 avg. size 21834 bytes
INFO: [???] No. B Frames : 1652 avg. size 10864 bytes
INFO: [???] Average bit-rate : 3680800 bits/sec
INFO: [???] Peak bit-rate : 7760000 bits/sec
INFO: [???] BUFFERING min 17 Buf max 197234
INFO: [???] AUDIO_STATISTICS: c0
INFO: [???] Audio stream length 1322496 bytes.
INFO: [???] Syncwords : 3444
INFO: [???] Frames : 3444 padded
INFO: [???] Frames : 0 unpadded
INFO: [???] BUFFERING min 15 Buf max 395
INFO: [???] MUX STATUS: no under-runs detected.
Multiplexing subtitles (buttons) into mpeg
DVDAuthor:pumux, version 0.6.14-GfD-1.
Build options: gnugetopt iconv freetype
Send bugs to <gfd@boraxsoft.de>
2 [main] spumux 1088 _cygtls::handle_exceptions: Exception: STATUS_ACCESS_VIOLATION
330 [main] spumux 1088 open_stackdumpfile: Dumping stack trace to spumux.exe.stackdump
Error executing of command: spumux 'C:\Documents and Settings\Louv68\Desktop\Stargate Infinity DVD's\Temp\dvd\menu0-0.mpg_spumux.xml'
Results 1 to 13 of 13
-The Mang
guns1inger,Originally Posted by guns1inger
I'm the administrator on the machine and there is plenty of space left?
I'm an intermediate user, not a power user, so please bare with me. How do I go about checking if my OS (XP Pro) has switched permissions on me without my knowledge?
Thanks-The Mang -
It is unlikely to have changed permission, and if you have an administrator account that most likely isn't the problem. I just notices one of the non-highlighted errors was from trying to load a file that doesn't exist, so I was looking for a cause.
The log also recommends emailing Borax for help. He is a frequenter of this board, but is on holidays for a couple of weeks. The best I can recommend at the moment is that you try uninstalling DVD Styler, rebooting, then installing it again. Otherwise, be patient until Borax returns.Read my blog here.
Is this a common thing, for the OS to change permissions w/o your knowledge? A while back on a W2k machine, VobBlanker no longer would start right up. Windows would first ask if it was OK to run the program. I never made any changes. It just started doing that on its own.
-The Mang -
No, it's not common, although I have seen a couple of odd things in my time. If it has happened then it could be a virus or some other malware. I would put that to one side for the moment and concentrate of a few other basics first.
1. Have you installed anything new recently ? Codecs, Codec Packs (god forbid), a new version of avisynth ?
2. If you look at the folders in the error logs, do they exist ? Is there anything in them ? They should be easy to check as they are on your desktop.
3. Is your disk partitioned ? If so, do all partitions have space ?Read my blog here.
1. Have you installed anything new recently ? Codecs, Codec Packs (god forbid), a new version of avisynth ? Yes, I installed K-Lite Codecpack Full 2.77 linked from The FilmMachine home page, which the software author recommends. This was the only way I was able to get The FilmMachine to work. Should I uninstall it and use a different Codec(s) in its place? It seems most "All-in-One" software packages include their own installation of avisyinth, so this could be a possibility. They do not seem to recognize avisynth is already installed on the system and install it again. I have gone into Add/Remove Software and spotted a few instances of avisynth. If I remove one, one or more applications that uses it stops working.
2. If you look at the folders in the error logs, do they exist ? Is there anything in them ? They should be easy to check as they are on your desktop. Yes they exist, and files from the authoring process are in there.
3. Is your disk partitioned ? If so, do all partitions have space ? The disk is not partitioned. I must have 60GB or so left on the drive.-The Mang -
Lose it. I've read many times on these boards that those things reek.Yes, I installed K-Lite Codecpack Full 2.77
Hmmmmm. I've never run into this as I don't use "one-click-wonders," but perhaps if you uninstalled (not just delete) all old instances and then download and install one good one, you'll be in better shape.It seems most "All-in-One" software packages include their own installation of avisyinth, so this could be a possibility.
When's the last time you defragged the drive? Run your scan disk and defrag. Perhaps that'll help too. I have all my drives set to defrag once a week.The disk is not partitioned. I must have 60GB or so left on the drive.
I can't help with the rest of the questions. Apologies. -
Ran Antivirus - none
Ran Spyware check - none detected
Uninstalled KLite Codec pack & installed Xvid codec
Uninstalled ffdshow and installed most up-to-date version.
Uninstalled avisynth and installed most up-to-date version.
= DVDStyler working again
Thank you for the suggestions. Much appreciated.-The Mang -
It does not work again for some reason. It just stopped working, giving the same error as before. I thought this application was the best thing since sliced bread and doubly so, since it's freeware. It's incredibly easy to create great looking menu's with this thing "when it's working". Since the developers over at SourceForge don't have the common courtesy to reply to my forum message or email, I will not be sending a "job well done" donation anytime soon. I am an advocate of donating to the cause, especially when software is provided as freeware, but in this case, I'll be keeping my money.
-The Mang -
I believe I have finally solved this problem once and for all. The problem was DVDStyler did not like the temp folder having special characters. I removed one, and it is working again. Funny enough, this quirk is not mentioned in the operation manual. A quick email from the developers stating this minor problem would have been nice.
-The Mang -
The developer might not have been aware of the issue. It is unusual to have odd characters in the temp folders under most circumstances. I would not have found it on my system because I always set up a Temp folder in the root of each drive, and redirect output to there. I hate all the crap that builds up under Documents and Settings.
Read my blog here.
To help clarify what temp folder I'm referring to....it's actually the Default Folder in the settings which the user can change. Prior to starting to author the DVD, DVDStyler pops up a final dialog box named Burn, which allows you to set the Temp Folder, which I believe is the Default Folder\Temp\DVD => it adds these two subfolders. It is this folder(s) that I believe cannot contain special characters. At least in my case, it was an apostrophe. Removing it fixed the problem.Originally Posted by guns1inger-The Mang
Need help-Been using ripbot for sometime now....it has stopped working.
By clefus in forum Blu-ray RippingReplies: 3Last Post: 13th Jan 2011, 11:42 -
SVCD2DVD Stopped Working
By magic90 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 28th Sep 2010, 07:07 -
Capture stopped working
By Movie-Maker in forum CapturingReplies: 4Last Post: 28th Mar 2010, 21:15 -
Multiple issues with DVDStyler (Including menus not working)
By Xmetalfanx in forum Authoring (DVD)Replies: 3Last Post: 6th Mar 2010, 01:27 -
WMP stopped working?
By glowworm12 in forum ComputerReplies: 5Last Post: 22nd Feb 2008, 08:44
