I'm sure this question was asked before, but I'm not having very much luck finding any good advice on it. I am trying to convert a HDTV video file to DVD format so I can play it back on my home dvd player. What is the best way to do this so I keep most of the good quality video and sound? I know that there many different free programs out there, the only problem is not knowing how to use them all separately. Is there any good tutorial on how to do it?
I would appreciate some good advice with maybe some step by step on how to do it.![]()
try hdtvtodvd
also check out this link among many others around the forum:
http://forum.videohelp.com/topic309286.html
Try to determine if you are using .ts or .tp or .mpg files from your capture source. Then you can move on from there.
You'll need to decide to if you want to keep 5.1 surround sound if it is in the original recording. Some process are differenct to keep it. Some all in one programs may or may not keep the surround sound - you would have to research them to make sure they keep it intact.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Weird playback of a DIVX file on DVD player
By gastrof in forum Newbie / General discussionsReplies: 3Last Post: 9th Oct 2011, 20:07 -
DVD/BD player that supports MP4 file playback?
By RogerTango in forum DVD & Blu-ray PlayersReplies: 0Last Post: 15th Sep 2011, 01:09 -
Capture HDTV and Convert to approx. 350 MB avi file
By gapstar in forum CapturingReplies: 4Last Post: 29th Mar 2010, 00:18 -
Xvid AC3 file playback problem on Standalone DVD player
By kamol88 in forum Video ConversionReplies: 2Last Post: 21st Mar 2009, 03:38 -
How to convert .TS file to a format recognisable by an ordinary DVD Player?
By comag in forum Video ConversionReplies: 18Last Post: 12th Jan 2008, 10:10
