I am creating a cross platform application for DVDs and I need to be abe to uniquely identify a DVD inserted into the drive. there seems to be no easily accessible ID in the DVD spec - is that right?
My preferred route would be to use the same technique as used by the Apple DVD player - it calculates some sort of hash and uses this to store metadata in a settings file. The filename of this settings file is based on this has and looks something like this example:
95b83c96e7415c34.plist
On OSX there are low level services that will calculate this ID - but I need to do this on other platforms - does anyone know how this hash is calculated - or if not what strategies should I try for working out my own unique ID?
I would assume that the IFOs are unique per DVD. Therefore i would read the *.IFO files into memory and do a md5/crc on the bytes. The files are very small so it would be nearly instantaneous.
sony dvd player dvp-ns67p without picture
By kamran-ns67p in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Aug 2010, 13:44 -
Can I Drive an Apple LCD directly from a DVD player?
By xmiinc in forum Newbie / General discussionsReplies: 4Last Post: 14th Jul 2009, 20:49 -
Quicktime: native codes in Apple QT player?
By geneaum in forum Software PlayingReplies: 1Last Post: 12th May 2009, 08:02 -
HDV to Apple PNG or Apple Motion JPEG A
By kippard in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 1st Dec 2008, 15:46 -
Philips DVP-5990 player - A few questions
By DVantrease in forum DVD & Blu-ray PlayersReplies: 6Last Post: 17th Sep 2008, 13:25
Statistics
Newest guides
Latest tool updates
New media comments
