Results 1 to 12 of 12
  1. I am using MSU Denoiser for virtualdub and it takes me forever to use it even on a small dv file like 50mb. Until I can figure out Avisynth someone recommended I use Fast Recompress rather than full processing mode. Whats the difference? Is there a difference in quality, file size, etc? BTW, I always use the filers Smart Deinterlace, resize, and MSU Denoiser if that helps any.
    Fast Recompress still re-encodes, but avoids the colourspace changed forced by Full Processing Mode. The catch : you must use Full Processing Mode if you use filters. Something else to consider - most good noise reduction filters are slow, even in avisynth. It it not unusual for me to have jobs run 8 - 12 hours to process 2 hours of video.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  3. Its taking me about a hour and 15 mins to process a 125mb file. What happens if you use the fast recompress with the filters loaded? Does it just avoid the filters?
    Yep. Skips them. That combination of filters will be slow. You also haven't filled in your computer details, so I have no idea what sort of system you are working on. There are many denoisers, some of them much faster than the MSU Denoiser. Perhaps you should look into them. I am also curious as to just how much noise you really have from a DV source. DV is usually pretty good unless used in low light.
  5. I am using it on a old 533mhz pc, and yeah I am using the minidv indoors at low light.
  6. Always Watching guns1inger's Avatar
    It would almost be quicker to hand clean every frame in photoshop
    Unfortunately these are very processor intensive filters, and you are working your CPU as hard as it can go. The only way to speed this up is to buy a new PC.
  7. The Old One SatStorm's Avatar
    Forget the MSU filters with your PC.
    The only filter close alternative you have is the following (use the filters in this specific order):
    deinterlace: unfold
    Static Noise reduction ( leave defaul value, that is "6" )
    Video DeNoise (leave the default settings)
    Dynamic Noise reduction ( set the value to 3 - 6, but not more)
    deinterlace: fold
    Smart Deintarlace
    Resize
    If your source are PAL VHS tapes, on the top of the filter chain, add "rmPAL"
    That way, you have the fastest possible way, decent picture filtering.
    Good luck and inform us about the results and the needed time
    i think your processor is too slow to make it go fast, i have never tried it, but i know computers and that processors can't really do much image and video editing.
  9. Always Watching guns1inger's Avatar
    I can remember when that was state of the art, and I used to do video work on something similar. It can do it, but it will only do it as fast as it can - which by todays standards isn't very.
  10. The Old One SatStorm's Avatar
    I can remember the days that 486 was a "state of art" PC. So ZX Spectrum 128K or Amiga 500....
    His CPU needs about 9 hours to convert 90 min to half D1 using the filters I suggest to him. Using CCE that is...
    it can do it, but it sure works slow, if i went over to that computer i would go nuts
  12. Mod Neophyte Super Moderator redwudz's Avatar
    I remember many times in the past with a 400 Celeron encoding SVCDs overnight for 11 - 15 hours. But it's really not that bad. The results should still be the same as the faster computers around these days. It just takes more time.
  1. Need earlier versions of MSU Denoiser plugin for virtualdub
    By cybertheque in forum Video Conversion
    Last Post: 15th Oct 2008, 16:32
  2. DV capture taking forever
    By Kihon in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 16th Jun 2007, 14:08
  3. VCDHelp.com taking forever to load?!?!
    By pijetro in forum Computer
    Last Post: 5th Jan 2007, 08:49
  4. Adobe Premiere taking forever to load up
    By liquidsub in forum Editing
    Last Post: 6th Mar 2005, 14:13
  5. SVCD encoding taking forever! whats up??
    By ruckus1 in forum Video Conversion
    Last Post: 18th Apr 2003, 23:56
About   Advertise   Forum   RSS Feeds   Statistics   Tools
