Does anyone know of a place which lists DVD players which have hacks to skip the User Operation Prohibited actions? The UOPs are what makes it so that you can't skip the commercials, previews, FBI Warnings, etc. I'd really like to find the players which have UOP hacks enabled through the remote codes or firmware updates on DVD.
I've viewed the DVD hacks here at http://www.videohelp.com/dvdhacks, but I can't seem to search the comments. That means I have to look at a specific DVD player to see if it has a hack. I'm looking to get a new DVD player, and one of my primary criteria is being able to skip UOPs.
I've never seen one myself. However, you can RIP a disc, remove the UOP, and burn a new copy.
Google is your Friend
Oppos can,you hit Stop then Menu...it then goes to the main movie.
Not to mention Oppos play PAL and can be made region-free.
I know of no such list. Some years ago when certain Chinese made DVD players (ie. Apex, Sampo, etc.) could have their firmware replaced with truly hacked firmware, it was possible to get new hacked firmware with this feature. These days when people talk about "hacks" they are referring to entering codes on a remote control to turn on certain features that are off by default. I've never heard of any players that you let you skip PUOs by simply entering a code on a remote control.
Like MOVIEGEEK said, the Oppos can do it. It's a nice feature, too. For example, in the FAQ for the 970HD over at the AVS Forums, it says:
http://www.avsforum.com/avs-vb/showthread.php?t=682896DIRECT PLAY:
To skip over the majority of warnings, promos, etc:
As soon as the DVD will allow:
1. Press Stop
2. Press Menu
"Direct Play" may appear briefly on the screen and the movie should begin.
DVD playback software that ignores UOP?
By RarelyEvil in forum Software PlayingReplies: 4Last Post: 2nd May 2009, 01:16 -
Multi-Region Hacks for SD DVD Playback Using Blu-ray Players
By Big C in forum DVD & Blu-ray PlayersReplies: 4Last Post: 14th Jul 2008, 18:27 -
Want to add UOP
By jcdm in forum Authoring (DVD)Replies: 9Last Post: 5th May 2008, 14:40 -
UOP for FirstPlay
By grzegorz in forum Authoring (DVD)Replies: 2Last Post: 9th Apr 2008, 07:58 -
Are there any players/firmware hacks to allow skipping of warnings/preview?
By Sephiroth666 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 14th Mar 2008, 07:37
