Not able to convert some .flv's I hve into MP4's for some reason. When I click the 'encode' button, the process is finished in about a second and there's no video file anywhere.
Searched the forums before posting and saw that some people with similar problems had to select the "Invert Mapping" in the Audio tab to fix it but this isn't working for me. I'm probably missing something pretty obvious but I think I have the binaries installed correctly. Here's the log:
Encoding started on Mon Aug 13 20:55:41 EDT 2007
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
configuration: --enable-memalign-hack --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads --enable-x264
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
built on Apr 15 2006 04:58:19, gcc: 4.0.1 (Apple Computer, Inc. build 5250)
[flv @ 0x5597b8]Unsupported video codec (4)
[flv @ 0x5597b8]Unsupported video codec (4) <-----This Line Repeats A Lot So I Edited It
Seems that stream 0 comes from film source: 1000.00 (1000/1) -> 29.83 (179/6)
Input #0, flv, from '/Users/anthonynorkus/Desktop/mx vid/2020743104.flv':
Duration: 00:03:58.3, bitrate: N/A
Stream #0.0, 29.83 fps(r): Video: 0x0004
Stream #0.1: Audio: mp3, 22050 Hz, stereo
Output #0, mp4, to '/Users/anthonynorkus/Desktop/mx vid/2020743104.flv.ff.mp4':
Stream #0.0, 29.97 fps(c): Video: mpeg4, yuv420p, 640x352, q=2-9, 940 kb/s
Stream #0.1: Audio: aac, 48000 Hz, stereo, 96 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Unsupported codec (id=0) for input stream #0.0
Gotcha. Thanks for the quick reply.
Since I couldn't convert these .flv's, I just uploaded them to YouTube and was able to download them from there with TubeSock. Quality wasn't that great but I was able to get them on my iPod finally.
Just thought I'd mention it in case anyone else was having the same problem.
I've used this site's services: http://vixy.net/
Sometimes it converts flv's that give ffmpegX or MPEG Streamclip fits.
The more tools, the better.
ok, i preface this by admitting i am an eternal n00b myself, but hopefully as such my suggestion will be useful to other n00b's!
i struggled on and off for a few days to find a way to convert my flv's for free on a mac. i tried every compatible software on this site, and everything i could find off the internet, you name it i tried it.
the only thing i didn't find suggested anywhere was the one thing that has worked for me.
use iMovie to drag in flv files as clips. drag the flv file into an open iMovie project. iMovie automatically converts the flv to a dv. this can take a very long time, depending on the file size, and iMovie can only convert one at a time, so i don't suggest trying this at home unless you have a lot of time on your hands.
once it's done importing your flv, you drag the new "clip" directly from iMovie to your desktop. it will save to your desktop as a dv. finally, you can drag this into iTunes, and convert the dv to an mp4. iTunes can't convert the mp4's directly, but it can convert the dv's. voila. iPod compatible mp4's from stubborn flv's. done. quality seems comparable to the original as far as my senses can perceive. (then again i've been sitting here for a while.)
again, this is super time-consuming but it gets the job done for free. i'll be nicely embarrassed if someone tells me that there is a simpler way to do this or this has already been discussed, but i'll be happy to be enlightened, as long as the whole schpiel is helpful to some other poor n00b in the end. nobody told me how to do this, so hopefully i save someone else the trouble.
Shadow box after converting to Mpeg2/MP4/FLV
By LouieLand in forum Video ConversionReplies: 6Last Post: 1st Feb 2010, 13:11 -
Best way for converting VOB to FLV, AVI, MP4
By lana2000 in forum Video ConversionReplies: 13Last Post: 22nd Feb 2009, 09:56 -
Codec type mismatch for converting MP4 to FLV
By swashbuckler75 in forum ffmpegX general discussionReplies: 2Last Post: 24th Apr 2008, 12:28 -
problems converting to flv
By devriesfilms in forum MacReplies: 7Last Post: 2nd Apr 2008, 12:36 -
Help converting .Mp4 to .flv
By amberayoder in forum ffmpegX general discussionReplies: 3Last Post: 18th Jan 2008, 16:24
