Xbox 360..
I Plugged It in all correctly, I tried different wires but the picture flashes for a split second, all there is, is sound and a msg sayin somethin like "not allowed to record" what should I do?
Product Item:
http://www.qvcuk.com/ukqic/qvcapp.as....yah.UKEL-UK21
If anyones knows any DVD Recorders that DOES allow you to record Gaming Console + HD + VCR (If Possible) Please Tell Me.
Results 1 to 13 of 13
I wonder if one of theses would work:
http://www.mcminone.com/product.asp?...5Fid=80%2D4280
Do you have the video set properly? You will most likely need the xbox video set to 480i (maybe 480p) in order for recorder to recognize it.
Google is your Friend
Elo Krispy Kritter, Erm I had it via Scart Into The DVD Recorder And I then tried the "red", "yellow" & "white" wires and it still didnt work..
And pinetop I'd prefer not to buy any external stuff for it has the dvd recorder should do as it says..Record.
The msg that comes up basicly tells me I'm not allowed to record my xbox 360, but yet I've seen xbox 360 recordings off other dvd recorders...
Have you tried to record copy protected VHS tapes and DVDs with your recorder?
If yes, did you also get a "not allowed to record" ?
Are the red, yellow, & white "wires" RCA cables or video composite?
This device will allow you to record copy-protected VHS, but I don't know about the HD or gaming console.Originally Posted by pinetop
I know. I'm not sure if he has the output on the xbox set wrong or if something is causing the recorder to detect copy protection. I leaning towards this being a setting issue. Anyhow if you have a DVD recorder, most if not all are protection sensitive, so for $ 25 bucks you solve alot of worries. But I'm also a pack rat gadget guy.Originally Posted by RowMan
Okay, I'll keep playing with the wires but honestly i tried everything and It says I'm not allowed to record it...so annoyin.
The signal is dirty. I doubt it's settings.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Most of the posts and references that I've seen regarding 360 recordings, the users are connecting the xbox to a VCR, then the VCR into a capture card/dvd recorder.
As the xbox is a M$ product, and they are big on copy protection, I suspect it was designed this way on purpose.Google is your Friend
Yep ^ And I rang up Funai, and they said that basicly there system is really soft and can easily detect copy right protection..jus gunna send it bak to QVC and buy another.
Good luck. Just about every recorder, if not all, on the market will detect copy protection. Some even raise the flag when the input signal is unstable, ie a old VHS tape, dirty vcr heads, worn dvd player laser, or a different type of signal like a camera or game console. An unstable signal causes this, thus the stabilizer suggestion.Originally Posted by rhem
You may want to get a Hauppuage PVR USB2. It will copy protected tapes and boardcast flagged programing.
Yea your right, I may just stick with my current DVD Recorder..and i refuse to record via my PC...
I can't get my Wharfdale DVD recorder to record in 16:9
By AndyLGR in forum Newbie / General discussionsReplies: 7Last Post: 12th Jul 2011, 08:27 -
DVD Recorder will only record when TV is switched on
By jiminwatford in forum DVD & Blu-ray RecordersReplies: 23Last Post: 18th Apr 2011, 14:03 -
Magnovox/Funai recorder+ TDK +R media on a Oppo HD970 player= choppy video
By videobruce in forum Authoring (DVD)Replies: 10Last Post: 2nd Nov 2009, 12:40 -
Magnovox/Funai 2160 recorder; video AGC issues. Suggestion for a TBC
By videobruce in forum DVD & Blu-ray RecordersReplies: 7Last Post: 13th Jul 2009, 12:24 -
any way to record from TV to DVD recorder?
By thedriver2200 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 10th Jun 2008, 12:37
