...... and all I get is muffled sound and loud hiss. Obviously the disc is copy protected. I've tried DVD Audio Ripper, I've tried DVD Decrypter and then extracting the audio from the VOB file using VOB Edit, but neither work. Does anyone have suggestions?
Thanks!
Roberta
Use DVD Decrypter IFO Mode, and enable Stream Processing. Select audio track in the main program you wish to extract and set Stream Processing option to Demux. Unselect everything else and leave it with Direct Stream Copy option. Hit Copy and this shoud extract your audio. You have the option under Tools/Settings/IFO Mode to split your audfio track by chapter, or to extract a single audio file and then split it as you see fit in Sound Forge or something similar.
Decrypter is an old prog and not updated for a while. You will have to use newer software like AnyDVD to rip to your HD and than use Decrypter or TNPEGEnc to extarct audio. After you can use other audio editing tools to split the songs.
Try this DVDFab HD Decrypter>DVDD in IFO as suggested to rip your audio....but what will you do with the AC3 audio? convert to what? write to cd right?.....
"I typed the word Google into Google. Guess what came up? Everything."
"What we've got here is failure to communicate"
Also make sure you are copying the ac3 or pcm/wav soundtrack. If you copy the dts track (if available) you will only be able to play it back in software that has a dts decoder in it. You are better off using ac3 or the linear pcm tracks as it is much easier to convert to wav for cd burning or mp3 compressing.
Thanks for the help, guys. I tried DVDFab Decrypter before trying DVD Decrypter but not IFO mode as suggested. I want to burn the extracted PCM tracks to CD as I don't think I should have to buy a copy of the CD to hear the music in my car.
AC3? I never touch the stuff when uncompressed audio is available.
Thanks again!
Roberta
There is a number of tools you can use to simply convert PCM files into WAV's, and then use any CD burning software (such as NERO) to make a regular Audio CD. You will need to make 2 CD if you want to have all the tracks handy. Conveniently enough, the show on DVD has been devided into two 1-hour segments with audio nicely faded out and in. I guess they figured that some people would be doing exactly what you wish to do.
DVD to MPEG2, extract mult audio tracks, subtitles for replay in WD TV Live
By Jacoman in forum DVD RippingReplies: 5Last Post: 16th Mar 2010, 09:40 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeGrow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 13:40 -
My DVD rip w/ no audio
By towarmforacoat in forum DVD RippingReplies: 1Last Post: 28th May 2009, 11:03 -
Whom do you prefer - Bob Seger or Bruce Springsteen?
By yoda313 in forum PollsReplies: 52Last Post: 27th Nov 2008, 22:14 -
Audio Rip from DVD
By MI6 in forum AudioReplies: 1Last Post: 8th May 2008, 04:32
