Hi all,
An acquaintance of mine wants to record footage from his PlayStation 3 while playing a game. He's not very technically minded, and wanted to know if there was a lead that splits HDMI to HDMI and S-Video.
Now I know there's not a cable, why it wouldn't work etc... but I was wondering, is there any kind of converter box available that he can plug into the middle of his setup, which would provide him with an HDMI pass-through and S-Video output socket?
I know nothing about his equipment, so I don't know if or why it needs to be S-Video, so I'm just assuming it does.
If anyone knows of such a device, could they point me - and him - in the right direction?
Many thanks for any advice on this.
Thread: HDMI to S-Video
I think he just needs the PS3 video cable:
http://www.cduniverse.com/search/xx/...ideo+Cable.htm
I don't know if the PS3 will display both over HDMI and s-video at the same time.
Ah, right.
To be honest, I didn't give that a thought - the reason being that I have a Virgin Media V+ box (basically a Scientific Atlanta TV Drive), and when you connect it via HDMI, the standard outputs are disabled.
Stupid me! I just presumed the PS3 would be the same. I'll look into whether the PS3 outputs to both simultaneously, and advise him accordingly. Thanks!
Hey i am having the same problem with this sort of thing, you see i play on the Xbox360 and i record with a Dazzle DVC 100 which is not a HD Recorder, how ever i want to play in HD but record in normal. Dazzle does not let you do this so i think i need a HDMI to S-Video or a HDMI to AVI adapter/convertor can you please point me out if these cables exsist and if they do where i would be able to purchase them.
It wouldn't be a cable. It would be similar complexity to a display card. HDMI has HDCP issues. Analog component would be more likely to work.Originally Posted by mrlazyx
Check out the HAVA that converts HD analog component to 480i/480p.
http://www.myhava.com/product_hava_platinum_hd.htmlRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / HDTVReplies: 16Last Post: 25th Feb 2012, 16:20 -
Is there an HDMI to RCA audio splitter cable for older 1.0 HDMI tv's?
By Lord Stinkfoot in forum DVD & Blu-ray PlayersReplies: 22Last Post: 10th May 2011, 16:33 -
HDMI Wall Plate>>Quality?----HDMI over Cat5E/Cat6????
By cpeters12 in forum DVB / HDTVReplies: 5Last Post: 28th Jan 2011, 03:27 -
xbox 360 hdmi problem (hdmi works on other hdtvs but not mine
By dmiklo in forum CapturingReplies: 0Last Post: 23rd Sep 2009, 16:51 -
multimedia player connection via hdmi but monitor doesnt have hdmi slot
By ozy666 in forum DVB / HDTVReplies: 1Last Post: 25th Apr 2009, 09:40
