Okay, I edited some home video from my Sony HC5 with vegas, shoved a few tunes in here and there, bit of standard bits of txts, nothing fancy, them exported it as an mpeg2 HD file to play on my external Helios Media player. All works there, no problems at all, plays fine on my media player. One of my relatives wanted a copy of the file to play on her PC, so I dragged it over and went to play it, it plays fine up untill the 43 second mark, where it just stops! I tried converting it to any other format with Canopus ProCoder, converts fine, upto the 43second mark and just gives in! So I tried converting the ORIGINAL copy which is on an external hard drive, converts fine - upto the 43second mark!! what is going on here?! Its totally confuzzeled me, so any help would be appreciated!
Mick
Thread: Damaged m2t file?
Download the 21 day eval of VideoRedo and run your M2t through Tools-->"Quickstream Fix"
Yup.. ive done that already, and it does nothing to help at all!! This is doing my head in! lol. any other ideas buddy?Originally Posted by Soopafresh
There are half a dozen apps which will also fix mpeg2 TS files.
Mpeg2repair is very good (but slow). Still, I guess I'd start with this one first.
ProjectX - Tremendous power, but not the easiest app to use.
AviDemux2 - Copy audio and video back to new Mpeg2TS file.
TSremux
Mpegstreamclip
Thanks for the help mate, this is what mpeg2repair says..
MPEG2Repair: C:\Documents and Settings\Mick\Desktop\superweezy.m2t
Sequence Frame 1091(10-B) / Time 0:00:43 :
Error: Packet 759962 has no TS Sync Byte.
Error: Can't find next TS Sync Byte. Terminating operation.
Additional error(s) detected. Increase VerboseLogLevel in INI file for details.
FileInfo: Last video errors span 69 bytes at file offset 143327183
Sequence Frame 1092(10-B) / Time 0:00:43 :
Info: End of MPEG2 sequence
Sequence Summary:
File Size Processed: 136.69 MB, Play Time: 00h:00m:43s
1440 x 1080, 25.00 fps, 25.00 Mbps (25.07 Mbps Average).
Average Video Quality: 121.95 KB/Frame, 0.64 Bits/Pixel.
MPEG Audio.
1 of 1092 video frames found with errors.
0 of 0 audio frames found with errors.
69 corrupted video bytes in file.
0.000000 seconds of video timestamp gaps.
0.000000 seconds of audio timestamp gaps.
End of Log
Not good. You've got a corrupt file. Try the others, but they'll almost certainly stop there as well. Bummer.
Yup, tried em in a few other progs and got the same.. they just all stop at the same point! But yet my helios will still play them from an external HD. Is there anyway I can export the video back to my HC5 and then back again? Hmm!
What is a M2T file? How do I...?
By Sal C in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 1st Oct 2007, 17:17 -
What is the best /.m2t/HDV file player(s) for the PC?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 28th Sep 2007, 18:04 -
Captured HDV file.....why does renaming m2t file to mpeg work?
By Rudyard in forum Camcorders (DV/HDV/AVCHD)Replies: 6Last Post: 8th Sep 2006, 00:02 -
m2t file to mpg?
By David9799 in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 22nd Apr 2006, 19:43 -
What is a .m2t file?
By David97 in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 9th Apr 2006, 22:47
