1. When recording a Deul layer disc, do you need to finalize the first layer before using the 2nd layer?
2. Can you pause through commercials when recording a program?
After you finalize a disc, it can no longer be written, regardless of type (SL or DL). Just use the DL discs like you would a SL disc.
If you are manually recording, you can stop/start/pause as often as you like.Google is your Friend -
You have to finalize the first layer of the disc, before you can go and use the 2nd layer. I unfourtunatly learned this the hard way this weekend plus it says so in the manual.
What type of discs (-R or +R)?
I only ask because from what I've read, -R discs seem to be treated as two seperate SL discs and aren't widely supported.Google is your Friend -
Its + R. Standard Verbatium deul layer stuff. The machine works really well btw for anybody whose thinking of getting it, or its american counterpart.
Very well. And sorry for the misinformation.
panasonic ag-dvx100 questions
By sonny crocket in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 11th Jan 2010, 20:18 -
Panasonic AG-1980P and TBC Questions
By icon in forum RestorationReplies: 6Last Post: 19th Dec 2009, 23:34 -
Pattern effect / recording or playing on Panasonic combo machine
By mdeange3 in forum Newbie / General discussionsReplies: 0Last Post: 1st Jul 2009, 16:43 -
PV-GS38 (Panasonic Camcorder) questions
By Nator in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 13th Jul 2008, 21:46 -
Help ! - I can't get my Panasonic DMR-HS2 to open - crazy machine......
By agent31 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 13th Sep 2007, 02:12
