VideoHelp.com Forum
    My new computer will not recognize my Canon Optura-10 camcorder. Since my old computer does recognize and download from the camcorder, I know the problem does not lie with the cable, the device or the softwares (all updates were made).
    Device manager doesn’t see the camcorder, as well as Windv who tells me: error: device not found. But the IEEE1394 card acknowledges with a “ping” the firewire cable when I plug it.
    I admit, I am not that good when it comes to computer so I need help Thanks in advance for any help. Anick.
  2. Member gadgetguy's Avatar
    Is the computer described in your profile your old one or new? Describe your new computer.
    Buy My Books
    It’s an Intel Core 2 CPU 6400 @ 2.13GHz, 2GB ram, Window XP with service pack 2. Do you need anymore description like the kind of motherboard and such? If you need more please tell me, as I said before, my knowledge in computers is limited. Thanks! Anick.
  4. Member gadgetguy's Avatar
    Is the IEEE1394 a plug in card or is it built into the motherboard?
    Buy My Books
    I have one that came with with my casing (Antec P160W Anodized Alum... with front IO ports) and the other is with the Audigy 2 card I added later. Both do not recognize the camcorder. My casing also comes with USB ports and they work very well. Anick.
  6. Member gadgetguy's Avatar
    Do you get the "ping" noise from both the front port and the one on the Audigy card?
    Buy My Books
  7. Member classfour's Avatar
    Borrow a cable - it might have gone bad
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  8. Member p_l's Avatar
    Was your old computer - the one that did recognize your Optura - XP SP2 as well?
  1. Computer won't recognize all my memory
    By ricoman in forum Computer
    Last Post: 1st Nov 2010, 16:28
  2. Computer won´t recognize DVD disk
    By dexter30 in forum Media
    Last Post: 4th Sep 2010, 14:52
  3. Dell Computer will not Recognize DVDs
    By w6rlf in forum Newbie / General discussions
    Last Post: 29th May 2010, 11:42
  4. Computer won't recognize my Mini-DV Camera
    By mschwennes in forum Capturing
    Last Post: 14th Dec 2007, 14:50
  5. Sonic won't recognize DVD, computer does ...
    By LittleQueenie in forum Newbie / General discussions
    Last Post: 17th Oct 2007, 13:06
