VideoHelp.com Forum
    Hello y'all, I used the WinAVI to convert rmvb files (real player files) to VCD (MPEG files), after the successful conversion, the VCD file plays fine on my computer using Windows Media PLayer; however, when I go and play it on my DVD player, the audio and the visual are out of sync. I don't know why it happens like that when it just plays fine on my laptop? Can anyone help or have any suggestion to correct this?
  2. Member ZippyP.'s Avatar
    Try something besides winavi for a start, or perhaps try another player since it plays ok on computers.
    PCs are much more tolerant of things that cause sync errors on standalone DVD players. One possibility is that you used some bad settings on your conversion. For example, if the video bit rate is higher than normal for VCD (1150 Kbps constant bit rate is the norm), that can cause sync errors. You might try using the program Super, which is pretty easy to use and should give better results than WinAVI. Nobody here thinks much of WinAVI.
  1. audio sync problem, how to work out progressive audio sync delay
    By jolt321 in forum Newbie / General discussions
    Last Post: 10th Apr 2012, 21:09
  2. Replies: 0
    Last Post: 22nd Dec 2010, 22:17
  3. VCD to PSP - Audio out of sync in last five minutes
    By BozQ in forum Video Conversion
    Last Post: 2nd Apr 2009, 22:43
  4. Audio out sync using Sony BDP-S350 Blue-ray Player
    By justmehere in forum Video Conversion
    Last Post: 26th Jan 2009, 18:58
  5. Replies: 1
    Last Post: 12th Nov 2008, 04:53
