VideoHelp.com Forum
Results 1 to 19 of 19
Thread: WinDV Crash?
    I have been using WinDV religiously since I got my newer camera. So I go to use it tonight and now it crashes when I hit the capture button and video starts to stream. Any thoughts on this? I would really like to stick with WinDV if at all possible.
    Regards,
    -P
  2. Member gadgetguy's Avatar
    Define "Crash". BSOD? Lock up? Reboots?
    Buy My Books
    Says Microsoft Visual C++:
    Runtime Error
    Regards,
    -P
    Not sure if it helps your particular situation, but there is an issue with WinDV controlling cameras directly. Start the tape with the controls on the camera, then hit "Capture" in WinDV.
    Jim
  5. Member gadgetguy's Avatar
    What's the exact text of the error including any numbers?
    Have you installed any other programs lately?
    Buy My Books
    Jim44: Thats what I have been doing.
    Gadgetguy: No numbers, but it says something about: Runtime has caused this program to terminate in an unusual way.
    No numbers or other explanations.
    Regards,
    -P
    Have a look in the application event logs (Right-Click My Computer -> Properties, expand the Even Logs tree and click on Application) at the time of the crash and see if anything is logged.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Do you think it is either the hardware or software failure? Software may need to be re-installed and check your harddrive. (check disk scan and defragmentor)
    Well I am at a loss, since like I said it was working fine. No changes at all either hardware or software.
    Regards,
    -P
    Do you have VC++ installed? I used to get a error like that on my web browser, whenever a site would be a conflict. The debugger would be set off and ask if I would like to debug.
    Have you checked the cables? Device drivers? Do you get any stills? What os are you using?
    Soulds like a delimia.
    I had a problem before with batteries that would not hold a charge.
  11. Member gadgetguy's Avatar
    I'm still waiting for you to answer Guns1inger's question...
    Buy My Books
  12. Have you tried a different capture tool (e.g, the one built in with Windows Movie Maker)?
    Doing so would help determine if it is a specific WinDV problem or a more general problem with some of the drivers etc provided by the OS that capture programs have to use.
    John Miller
    enosoft - high performance tools for music and video
    Home of the Enosoft DV Processor - Free for personal use!
    Nothing in the event log, regarding WinDV.
    Regards,
    -P
  14. Member gadgetguy's Avatar
    Anything at all, at the time of the crash? An error that causes a program to crash might not identify the crashed program.
    Buy My Books
    Nothing, just the VC error reported up above.
    This is the screenshot of the error. No evidence anywhere else of anything.
    Regards,
    -P
    I'd say run Dial-A-Fix on your PC.
    http://djlizard.net.nyud.net:8080/so...v0.60.0.24.zip
    Maybe you are missing Visual Basic Runtimes?
    http://www.microsoft.com/downloads/d...displaylang=en
  17. Member gadgetguy's Avatar
    I've never heard of Dial-A-Fix so won't comment on that, but re-installing the VB Runtimes is a good idea as one (or more) of them may have gotten corrupted.
    Buy My Books
  18. Member
    I know this thread has been dead awhile but I thought I would post my solution. Really dumb actually. The capture dir got somehow set to an invalid dir and was causing the program to but out with that error msg.
    Regards,
    -P
    Thanks for posting the solution!! I have just had exactly the same problem
    Al.
  1. Should I use WinDV?
    By tygger in forum Capturing
    Last Post: 6th Jan 2012, 17:23
  2. Windv to harddrive
    By runnernorth in forum Capturing
    Last Post: 12th Jan 2010, 04:36
  3. Cannot use windv with usb
    By Riff88 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 21st Apr 2009, 15:04
  4. WinDV
    By kippard in forum Capturing
    Last Post: 7th Apr 2008, 23:43
  5. Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
    By maxtrack in forum Newbie / General discussions
    Last Post: 11th Sep 2007, 00:38
