VideoHelp.com Forum
  1. Member vegasarian's Avatar
    Is there such a thing as Ink Jet printable (white faced) RW Dual Layer Discs? If so would anyone have a link to where to buy in the UK?
    I'm slightly confused why you want printable RW's but who am I to comment.
    In the UK www.ukdvdr.co.uk are always worth a look and are relativeky cheap although it can sometimes be difficult to find exactly what you are after.
    I have had a look through their printable DVD media but al the DLs were +R
  3. Member vegasarian's Avatar
    After a bit more research it seems there is no such animal, printable or otherwise but thanks for your help IKnowNothing!
  4. Member ntscuser's Avatar
    I've yet to find a single layer DVD-RW with printable label let alone dual-layer
    For anyone curious, I use separate DVD-RW's to test different types of file. One for Video_TS folders, one for image files and one for data. As all three have the same box and label I sometimes get them mixed up
  1. Question about Ink Jet printableDVD's
    By flyin-lowe in forum Authoring (DVD)
    Last Post: 23rd Nov 2010, 20:40
  2. Printable Dual Layer DVD's
    By ozab in forum Media
    Last Post: 7th Oct 2009, 13:12
  3. Dual Layer hub printable media??
    By garstan in forum Media
    Last Post: 21st Oct 2007, 14:50
  4. Replies: 5
    Last Post: 7th Sep 2007, 14:06
  5. Printable Verbatim Dual layer
    By SilverBlade in forum Media
    Last Post: 16th Aug 2007, 23:19
