Hi, I have a video that is exactly 29:41.28 minutes long. I know YouTube only allows videos that are under 10 minutes so I have to divide this video into three parts.
My question is, how can I figure out exactly what bitrate to encode the video at so that I get the most (without going over the 100mb limit) out of each ~10 minute part?
use a bitrate calculator.
1200kbps total (audio+video) is safe.
resize to 320x240 before uploading.
1000-1100 kbps (mpeg4) video at that resolution is probably overkill.
gl
hmm, you could get www.VirtualDub.org, it has a bitrate calculator built in, or at least, when you have the Xvid codec installed.
1. Download Vdub, and unzip it, no install needed (you know it's save when you don't need to install it
2. Install the xvid codec
3 Open the file in Vdub, hit ctrl-P, select xvid in the left list, click Configure, click CALC button.
4. Fill out the fields, (target size, video time etc. ) and hit OK.
the target bitrate should be indicated now.
mail me when/if u have qiz'sRiver Tam: ''Can't look, can't look!'' My old avatar: dress, movies
Uploading a video to Youtube that will fill the ENTIRE youtube player.
By Clifurd in forum Video ConversionReplies: 16Last Post: 12th Mar 2010, 13:40 -
Encoding HD Videos for YouTube in Corel Video Studio X2
By Michiko280 in forum Video ConversionReplies: 2Last Post: 16th Feb 2009, 09:43 -
Video for youtube with no re-encoding after uploading.
By Alter-Divide in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 09:29 -
Correct settings for encoding video for the 'new' YouTube format?
By Captain Satellite in forum Newbie / General discussionsReplies: 0Last Post: 25th Nov 2008, 17:45 -
Youtube: Best settings for YOUTUBE in premiere pro? (encoding)
By vid83 in forum Newbie / General discussionsReplies: 6Last Post: 2nd Jun 2007, 18:52
Statistics
Newest guides
Latest tool updates
New media comments
