  1. What software do you generally use to demux an mkv file?
    I have a .mkv file containing an WMV3 stream and AC3+DTS audio tracks. I tried opening it in VirtualDubMod but when trying to save the new file I get the error "video frame 0 could not be read from the source. The file may be corrupt."
    I want to do make it an ordinary .avi so I can play it in Windows Media Player and use my own subtitle file.
  2. VH Wanderer Ai Haibara's Avatar
    If you really want to demux everything, use MKVExtractGUI (and be sure to install mkvtoolnix to the directory to which you installed MKVExtractGUI).
  3. That worked, thanks.
    Hi,
    I have a problem demuxing an HD video (wvc1,1920 by1080) from a mkv file.
    i tried MKVExtractGUI with mkvtoolnix but i can't find the avi file the program is supposed to create , i only found instead an empty txt file .
    Thanks for your help!
