I have 12 WMV clips that i downloaded couple of days ago, i wanted to join them with ASF Join but it can't. 11 clips out of 12 have same properties but 1 clip between them is different. I want a tool which can convert that clip into exactly like other clips so i don't have to re-encode all other clips.
Clips properties : (From Video Studio 10)
VIDEO
Windows Media Video V8
24 bits, 320 x 240, 30.000 frames/sec
AUDIO
Windows Media Audio V8
32.000 KHz, 16 bits, Stereo
Aspect Ratio: 1.33 : 1.00
The different clip's properties :
VIDEO :
Windows Media Video V7
24 bits, 176 x 144, 15.000 frames/sec
AUDIO :
16.000 KHz, 16 bits, Mono
Aspect Ratio: 1.22 : 1.00
I tried myself to convert it similar to other clips with Ulead Video Studio 10 using custom preset but ASF Join still says that this clip does'nt match with previous.
Windows Media Encoder should be able to, but you may have to use an avisynth script to resize the video and double the framerate. Also expect the image to look substantially lower in quality because it is only half the resolution and framerate of the other clips.
Ok, i have installed windows media encoder.
In session i use convert video file, after loading the target file it shows a screen (How do you want to distribute your content)
I Choose File Download(computer playback), then next.
Now it shows encoding options, what should i do here?
There is no option to make custom preset.
Can you please be more specific.
Thanks for the links, i will read it and post my results later.
Saving a clip (segment) as wmv in Movica
By anon_private in forum Newbie / General discussionsReplies: 19Last Post: 26th Oct 2010, 20:16 -
How to Combine MP4 Clips and then to WMV & AVI
By gonwk in forum Video ConversionReplies: 3Last Post: 2nd Mar 2010, 08:35 -
combining WMV movie clips into one WMV clip
By blkwht240 in forum EditingReplies: 3Last Post: 5th Feb 2010, 00:41 -
Screensaver for WMV,MPEG-2 clips and JPEG pics
By rch15 in forum Software PlayingReplies: 0Last Post: 18th Aug 2008, 00:14
