I have a Sony RDR HX910 and very happy with the machine. It appears the hard disk drive was accidentally formatted. It has since be turned off with nothing added to the hard drive. Any suggestions as to how I can get back all of the programs? (approx 230GB lost I think).
Results 1 to 11 of 11
Sparky10000
Oops, didn't read the subject line properly.
Welcome sparky10000 .
Not a chance in a snow storm ... its all gone .
Pvexplorer is a tool used to extract data from pvr units .
We have some funny laws covering such devices here in the au , but everybody expects to be able to use these devices , even though they are considered illegal .
You'll get a laugh at what is "expected" by the public , and what is "illegal" .
Oh god .. I hope it wasnt your top quality p*rn??
The electronic components of the power part adopted a lot of Rubycons.
you mite be abbel to hook it up to you computor they have programs online you may have to bye to get back what you lost just look for harddrive recovery tools it might work as long as you have not copyed anything else on your hard drive if you have even 5 seconds then all is lost remember all thinks is possible as long as you believe i used dvd decryptor on a dvd rw disk that i erased and copyed it in iso format i retrived my shows but i cant get it back to dvd format so i would not do that unless you know how to return it back to dvd
Good grief man. One big run on sentence. If you really want to help, spend an extra few seconds and write in complete sentences. I read posts from users that can barely speak English, that are easier to understand.Originally Posted by ronparGoogle is your Friend
i didn't know you could read most morans can't
this forum is to help with problems professor not correct spelling or sentences. so enough with the smartass coments you got it or there is another way to solve this understand puss
OnTrack Data recovery software may be worth a try. Other than that you're probably SOL
--dES"You can observe a lot by watching." - Yogi Bera
The problem with data recovery is that most all DVD hard drives are formatted with many different OS systems. A good number may even be proprietary. As an example my Liteon/ilo units use fat 32 but it is tweaked for 64k cluster size. [This is an easy one]
Another example
When in the computer business a Lawyer developed HDD problems. Fortunately he stopped and did not try to correct the problem.
The drive was sent to a data recovery service by airmail, They were able to fully recover almost 80% of the files, and about 15% to 80- 90% of the files, 5% was lost.
Fortunately the files that meant the most were fully recovered.
The cost Not counting special airmail [ which was some $375] was $565.
If you know or can find out the format of your Sony and you haven’t tried to correct the problem and compounded the issue you MAY find a recovery service that will take the problem ON
Find out the price first [If that’s an issue]
I have a RDR-HXD770 abd have tried to read the Sata hard disk but it appears not to be recognised as conventional format
Does anyone know a programme to read the drive
LG DVD Recorder Hard disk Upgrade
By pchan in forum DVD & Blu-ray RecordersReplies: 36Last Post: 27th Jan 2012, 05:29 -
Saving dvd recorder hard disk videos says error
By xmanhattan in forum DVD & Blu-ray RecordersReplies: 4Last Post: 14th May 2009, 13:16 -
DVD Recorder hard disk to PC
By aqctv in forum DVD & Blu-ray RecordersReplies: 5Last Post: 21st Jan 2008, 17:36 -
Toshiba Launches New Hard Disk Recorder with HD DVD
By NICEBUD in forum Latest Video NewsReplies: 6Last Post: 11th Jul 2007, 07:20 -
DVD Recorder with hard disk
By pingping in forum DVD & Blu-ray RecordersReplies: 0Last Post: 15th Oct 2004, 11:23
