I am using Ulead DVD Workshop 2 but it is CRASHING when I set more than 4 chapters on my single 2hour / 4GB MPG title source file.
I need the 2 hour source file as I have a 2 hour audio file to attach to it (a commentary).
I tried attaching the commentary then "cutting" the 4GB source MPG into pieces - 2 problems 1) that crashes as well 2) it doesn't cut the audio file - each clip starts playing the 1 commentary file at the start.
I am using a 1 year old Dell VAIO SZ220 with 1GB RAM.
Any ideas on how to stop Ulead from crashing?
Any other programs I might use (need merge the MPG with my commentary WAV file, to add chapters and create a menu).
Well a couple of things .
When was the last time scandisk was run , followed by defrag ?
To cut it into piece's you could try http://www.squared5.com/svideo/mpeg-streamclip-win.html
You "2" issue is weird .
If you can output the mpeg clip as mpeg with the audio included , then do that instead .
Grab batchdemux from dvdauthor's website , or use mpegstream clip , to demux the mpeg .
Use besweet to convert audio to ac3 ... smaller file will result , but do not set to 64kbs or lower .
Then
Chapters :
Load m2v up via virtualmod .
Open notpad
Move the button on the time line forward till first chapter point is located .
Use left or right arrows for fine frame adjustment
Below time line is a box displaying frame's number
Use mouse to highlight , and copy
Paste in notepad and hit enter
Repeat till all chapter points located .
Close virtualmod when done
Save text in notepad as celltimes.txt
Launch rejig
Select author
Load m2v , then ac3 , followed by celltimes.txt in the appropriate area's
Select output folder , and let it rip
Done , basic title with 4 chapters .
If you want menu , check out my guides , one use's dvdauthorgui and show's the chaptering part .
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 02:04 -
Ulead DVD Workshop 2 replacement?
By msimon7 in forum Authoring (DVD)Replies: 26Last Post: 2nd Sep 2010, 09:25 -
Subtitle Workshop - audio sync issues/crashing
By ecc in forum SubtitleReplies: 3Last Post: 30th Mar 2009, 22:59 -
Ulead DVD Workshop 2 with Vista?
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2008, 02:48 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 02:55
