VideoHelp.com Forum
    When I export from Final Cut to DV, HDV, motion-JPEG, etc. it always seems like the colors are less saturated and there is less contrast. The settings are on "best", so it shouldnt be that.. Before exporting and on the camera they look fine. Does anybody have the same problem?
    Computer monitors have very different gamma curves than televisions (or the display on your camcorder). So what you're seeing may be normal. Transfer the video to your computer to your camcorder. If it looks ok on the camcorder there's nothing wrong on the computer.
    Ok, thanks! The thing that is weird though, is that it looks fine when viewed in FC, but a bit dull when viewed in Quicktime after exporting (on the same monitor)...
    It might be that FC is automatically adjusting the colors for the monitor where quicktime doesn't.
    Thanks for your answer! I will see if there are any settings for that.
  1. Changing contrast in premiere
    By Delora in forum Editing
    Last Post: 6th Jan 2011, 10:05
  2. Gamma vs Contrast
    By CSULB71 in forum Computer
    Last Post: 30th Apr 2010, 09:38
  3. Contrast of subtitles
    By Jomapil in forum Subtitle
    Last Post: 11th Nov 2008, 06:44
  4. Dyamic Contrast Ratio
    By snadge in forum DVB / HDTV
    Last Post: 29th Feb 2008, 19:44
