VideoHelp.com Forum
Thread: DVD Firmware
    Does anyone know anything about this?? I have a Philips Divx DVD player and it plays pretty much everything except GMC and Q-pel. My sister has a new model version. If I download the firmware for her dvd player and install it on mine, can I play these files?
    I can tell you 2 reasons why this probably won't work.
    1) If her model is different from yours, using the wrong firmware will fry your model. And you should be aware that sometimes the same model uses different chips over time and the firmware isn't compatible.
    2) I could be wrong, but I think QPel and GMC support has more to do with the decoding chip than the firmware. If I'm right about that, then upgrading firmware will make no difference if your chip doesn't support those options.
  3. Member Krispy Kritter's Avatar
    jman is correct. This isn't a firmware issue, it is a hardware issue. Most players can't play files encoded with those options anyway. Your best bet is to fix the files.
    Google is your Friend
  1. FIRMWARE for SONY DVD
    By yangp in forum DVD & Blu-ray Players
    Last Post: 11th Dec 2008, 14:44
  2. DVD writer with firmware.
    By gsingh13 in forum DVD & Blu-ray Writers
    Last Post: 17th Sep 2008, 18:59
  3. What's my DVD's firmware manufacturer?
    By b00h in forum DVD & Blu-ray Players
    Last Post: 5th Dec 2007, 14:47
  4. DVD Player Firmware
    By abercrombiedude0409 in forum DVD & Blu-ray Players
    Last Post: 31st Jul 2007, 13:10
  5. Need DVD-RW firmware
    By Strutinan in forum DVD & Blu-ray Writers
    Last Post: 13th Jun 2007, 07:19
