why does hd demand a separate port?why isn't av output good enough for playing hd content?
is there an improvement in quality if non hd content such as avi or xvid is outputted through hdmi port?
Results 1 to 12 of 12
Thread: hdmi and av output
Composite and s-video are low resolution, about 640x480. HD material is usually 1280x720 or 1920x1080.Originally Posted by gunukhan
Not really. Although it will depend to some extent on whether the player or the TV does a better job of upscaling.Originally Posted by gunukhan
i have samsung bordeaux man.so any opinion.
will a philips hd dvd player do a good job or a samsung(please give model numbers)
suggest some other players which do a good job with the model numbers
is there a difference in s-video and av out?
Are you talking about s-video vs composite (usually a yellow RCA connector)? S-video is better because it keeps the color channels separate from the luminance (grayscale) channel. This prevents some of the color artifacting that occurs when luma and chroma are sent down a single wire.Originally Posted by gunukhan
http://www.hifi-writer.com/he/video/index.htm
i was talking about the 3 cable output with 3 colors of red,yellow and white,can you also do me the favour of answering other questions that i have posted in the same forum because there are some mourons out there making fun of me being a newbie?
Yes, that's composite. Red and White are audio, yellow is composite video.Originally Posted by gunukhan
I am running a Sony 5 disc dvd player that supports upconversion to 1080i via the hdmi output - to my Sharp 46" 1080p lcd tv. I am very pleased with the results - and the picture quality is excellent. The only disappointment comes when you are playing an older non-anamorphic dvd, as the quality does not improve as dramatically as with a well mastered anamorphic dvd. I send the audio to my home theater via optical digital.
General quality over different cables, from highest to lowest:
HDMI, DVI
component, VGA
s-video
composite
RF
do converter cables do any good?for example u said hdmi is better than s-video,so will a s-video to hdmi cable do the same good job?
There's no such thing as a s-video to hdmi CABLE. Conversion from analog s-video to digital HDMI requires a smart device.
As I said in another of your threads, the quality will depend on many factors including how well the device converts the analog s-video to digital form and how well it upsizes, whether or not your HDTV will furhter resize the video once it recieves it from the HDMI cable and how well it does it, and how well your HDTV converts and resizes an s-video source.
If you're talking about connecting a DVD player to an HDTV, it's almost always better use HDMI to HDMI. If your DVD player doesn't have HDMI out it would be cheaper for you to buy a new DVD player than to buy an s-video to HDMI converter box.
Analog component Y,Pb,Pr (green-blue-red as output from most DVD players, HD cable/sat boxes and some computer display cards) is capable of SD 480i/480p or HD 720p/1080i.
Same goes for DVI and HDMI digital connections.
Composite (yellow) and S-Video are SD only.
Your TV has 720p resolution so when possible use a 720p source. Other inputs get upscaled to 720p inside your TV.
Capturing HDMI output
By Andrroid in forum CapturingReplies: 7Last Post: 6th Aug 2011, 01:34 -
RF output to DVI/HDMI Input
By torrentkid in forum CapturingReplies: 4Last Post: 19th Jun 2010, 02:41 -
Possible to output hdmi and optical output on the ps3??
By mrswla in forum DVD & Blu-ray PlayersReplies: 10Last Post: 3rd Feb 2009, 15:17 -
No HDMI audio output
By tcheema in forum DVB / HDTVReplies: 2Last Post: 11th Jan 2008, 22:00 -
HDMI sound output from TV
By chronicnight in forum DVB / HDTVReplies: 5Last Post: 31st Dec 2007, 20:25
